Indicators
Indicators
Noticed that when the headlight on my Z1000 is on the indicators flash more slowly - Checked battery on multi-meter when removed from bike and shows over 12v to fully charged - Should I check battery with engine running - Any thoughts ? Cheers all.
Re: Indicators
Most likely poor wiring - aged wires & connectors!
Re: Indicators
AlanB wrote:Noticed that when the headlight on my Z1000 is on the indicators flash more slowly - Checked battery on multi-meter when removed from bike and shows over 12v to fully charged - Should I check battery with engine running - Any thoughts ? Cheers all.
Did you check the voltage with the engine running?.
Re: Indicators
thanks guys - If I test battery with engine running, what am I looking for and what would it mean ? cheers
Re: Indicators
should be 13.8-14.5 running
Re: Indicators
Ahh great thanks - If it's not, what would that suggest the problem is ?
Re: Indicators
AlanB wrote:Ahh great thanks - If it's not, what would that suggest the problem is ?
Probably the Regulator/Rectifier, more so if it's the original one/s.
See the sticky at the top of this section on how to test.
Re: Indicators
Thanks - Had a new combined reg/rec 18 months ago and prob done 200 miles since - I'll check anyway - Cheers all.
Re: Indicators
I had the same problem on my LC turned out to be the flasher relay!
