Tank Lacquer Restore?
The lacquer on my A4 tank has a few blisters and some has flaked off, plus a scratch. The paint & pinstripes look ok. There's no bare metal or primer showing through so I wondered if it's possible to repair the lacquer coat, either by adding polish or some new lacquer?
Re: Tank Lacquer Restore?
yes
My advise is take to a painter who will flat it back to the base coat and re do all the lacquer coats
this is wise as there will be a reason the lacquer is lifting, so if only spots are done the rest will go the same way in time
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
along with some lesser makes
Z1300 A1,
KE175b, KE175F
Absolutely , as hartyb says , give it to a professional painter .
We all know a bit about something
0172 . Geoff Parr
