z1r rear mc
z1r rear mc
Hiya guys, a few questions to the more knowledgeable;
1, is the plastic reservoir available for sale anywhere
Or can this plastic be cleaned up?
2, is the 'o' ring available that sits inside?
3, what's the best way to clean out all the old brake fluid/crud?
cheers freddy
cheers freddy
freddyz1r
PUM 329
freddyz1r
PUM 329
- wheelysteve
Re: z1r rear mc
pm your address and i'll send you the o ring.
Cleaned mine out with a dremel and elbow grease !
Steve
Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
- wheelysteve
Re: z1r rear mc
that's the stuff !!
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Re: z1r rear mc
Thanks for the reply chaps
Steve, the o ring arrived safe and sound, thanks very much.
cleaned up nice (especially after a couple of dips into the ultrasonic cleaner ).
The fluid reservoir won't clean up properly
Cheers freddy
Cheers freddy
freddyz1r
PUM 329
freddyz1r
PUM 329
Re: z1r rear mc
freddyz1r wrote:The fluid reservoir won't clean up properly
Cheers freddy
yes it will u need a chemical called M.E.K its a band substance used in pvcu window repair and manufacture if u can get hold of it ive not got any now
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2026
Re: z1r rear mc
I put mine in the ultrasonic cleaner then in the dishwasher some come up like new some not so good but always better
hope that helps
hope that helps
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
along with some lesser makes
Z1300 A1,
KE175b, KE175F
Re: z1r rear mc
hartyb wrote:I put mine in the ultrasonic cleaner then in the dishwasher some come up like new some not so good but always better
hope that helps
this front one was done with M.E.K
Re: z1r rear mc
z1bman wrote:https://www.ebay.co.uk/itm/1-LITRE-PURE-99-9-MEK-METHYL-ETHYL-KETONE-SOLVENT-1L-2-BUTANONE-/26365003
just down the road from me will get some and give it a try
Z1300 A1,
KE175b, KE175F
Z1300 A1,
KE175b, KE175F
Re: z1r rear mc
hartyb wrote:z1bman wrote:https://www.ebay.co.uk/itm/1-LITRE-PURE-99-9-MEK-METHYL-ETHYL-KETONE-SOLVENT-1L-2-BUTANONE-/263650030231?clk_rvr_id=1524358751714&utm_medium=cpc&utm_source=twenga&utm_campaign=twenga&utm_param=eyJlcyI6MCwicyI6OTcyMDIzNywiY2kiOiIwMzU0OTc0ZmRlYzZkZjcyNWE5N2IxMzcyMWM0NDVmNyIsImkiOiIyNjM2NTAwMzAyMzEiLCJ0cyI6MTUyNTgxNTIzNSwidiI6Mywic28iOjE1MDAsImMiOjEwNDIzM30%3D&rmvSB=true
hope u know how to use it its for cleaning and melting scratches out of plastic window frames it melts plastic if left too long
- wheelysteve
Re: z1r rear mc
Freddy, glad you sorted the m/c.
This MEK stuff, do you use it neat on the plastic reservoirs ?
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Re: z1r rear mc
every day is a school day, learning and thanks for the heads up
Z1300 A1,
KE175b, KE175F
Z1300 A1,
KE175b, KE175F
Re: z1r rear mc
wheelysteve wrote:Freddy, glad you sorted the m/c.
Yes neat but its how much u use and how long its on the plastic
Re: z1r rear mc
Cheers chaps, I'll get some and give it a try next week
freddyz1r
PUM 329
freddyz1r
PUM 329
Users browsing this forum: Bing [Bot], relisysxx and 146 guests
