Hi all
I need a gpz1000rx r/h switch, or similar push/pull throttle for my elr to control the rs36 carbs.as the motion pro throttle hangs off the edge of the bars and is a long reach to switch controls. Any leads on a switch and whom can restore placcy switch's much appreciated.
GPz1000rx rh switch/throttle needed for elr
Re: GPz1000rx rh switch/throttle needed for elr
Thanks for the lead I bought it just hope it's push/pull and has lighting switch..
swampy wrote:Thanks for the lead I bought it just hope it's push/pull and has lighting switch..
yes it has twin cables the same switch as a 1000rx apart from the wiring length
Got a GTR1000 one if any use?
drew
drew
Users browsing this forum: No registered users and 154 guests
