Z900 rear brake light (outage) switch
Been looking for a NOS rear brake light (outage) switch for the Z900, this is the one that fits into a 3 wire block-connector under tank.
Have spoken with Phil at Z Power and these haven’t been available for 20 years and are generally not available as old stock (nor are repros), so most owners just leave it off. However, I’m a bit anal on this stuff.
The OEM part number is 28019-001 and the Z400 unit is 28019-002 which seems to be available in the States - does anyone know if this unit would fit?
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
- warren3200gt
Re: Z900 rear brake light (outage) switch
Don't know for sure but most 70's bikes used the same unit. z650's used a slightly smaller unit but does exactly the same job with the same con block. I got a nos "Yamaha" non branded one from ebay Germany for about £15 quid inc postage. Works just fine and has the same con block.
PUM 488 June 2023
warren3200gt wrote:Don't know for sure but most 70's bikes used the same unit. z650's used a slightly smaller unit but does exactly the same job with the same con block. I got a nos "Yamaha" non branded one from ebay Germany for about £15 quid inc postage. Works just fine and has the same con block.
Thanks Warren, do you happen to know the part number on the Z650 or Yam unit?
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
- warren3200gt
z650 part no 28019-001. don't know the Yam one, looked the same in the picture so took a chance and it worked out (for a change)
https://www.ebay.co.uk/itm/Genuine-Kawa ... SwLVZVtLvb
These are the KHI bikes that use the same unit
1982
650 CSR KZ650B
CHASSIS ELECTRICAL EQUIPMENT ('81-'82 H1)
1981
550 GP KZ550D (GPz)
650 CSR KZ650H
KZ550 Standard KZ550A
CHASSIS ELECTRICAL EQUIPMENT ('80-'81 A1
CHASSIS ELECTRICAL EQUIPMENT ('82-'83 A3
Police 1000 KZ1000C
CHASSIS ELECTRICAL EQUIPMENT ('78 C1/C1A
CHASSIS ELECTRICAL EQUIPMENT ('79-'81 C2
More »
1980
1000 LTD KZ1000B
CHASSIS ELECTRICAL EQUIPMENT ('79-'80)
650 Custom KZ650F
KZ1000 KZ1000A
CHASSIS ELECTRICAL EQUIPMENT ('77-'78 A1
Police 1000 KZ1000E
1979
1000 LTD KZ1000B
CHASSIS ELECTRICAL EQUIPMENT ('79-'80 B3)
650 Custom KZ650C
650 SR KZ650D
750 LTD (Twin) KZ750B
KZ1000 KZ1000A
KZ650 KZ650B
Police 1000 KZ1000C
1978
1000 LTD KZ1000B
CHASSIS ELECTRICAL EQUIPMENT ('77-'78 B1
650 Custom KZ650C
650 SR KZ650D
650 SR(KZ650D1)US
KZ1000 KZ1000A
KZ650 KZ650B
Police 1000 KZ1000C
More »
1977
1000 LTD KZ1000B
650 Custom KZ650C
KZ1000 KZ1000A
KZ650 KZ650B
1976
KH500
CHASSIS ELECTRICAL EQUIPMENT (H1-D/E/F)
CHASSIS ELECTRICAL EQUIPMENT (KH500-A8)
1982
650 CSR KZ650B
1981
550 GP KZ550D (GPz)
650 CSR KZ650H
Police 1000 KZ1000C
More »
1980
1000 LTD KZ1000B
650 Custom KZ650F
KZ1000 KZ1000A
Police 1000 KZ1000E
1979
1000 LTD KZ1000B
650 Custom KZ650C
650 SR KZ650D
KZ1000 KZ1000A
KZ650 KZ650B
Police 1000 KZ1000C
1978
1000 LTD KZ1000B
650 Custom KZ650C
650 SR KZ650D
650 SR(KZ650D1)US
KZ1000 KZ1000A
KZ650 KZ650B
Police 1000 KZ1000C
More »
1977
1000 LTD KZ1000B
650 Custom KZ650C
KZ1000 KZ1000A
KZ650 KZ650B
1976
KH500
PUM 488 June 2023
Excellent info, many thanks!
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
Remember Keith Ogden on here saying he had a nos one not long back...
z1bman wrote:https://www.ebay.ie/itm/KAWASAKI-Brake-Light-Indicator-Switch-OEM-28019-002-NEW-fits-KZ400-KZ440-Relay-/122297348052?hash=item1c797d6fd4
Thanks z1bman, there seems to be plenty of Z400 ones available in the States, but the wire colour coding is different - does anyone know if they work on the Zeds?
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
- warren3200gt
I would imagine they would. Internally I would think they would be identicle and its unlikely KHI would use a different circuit to one they have on other bikes already in use. Probably just a wire colour change
PUM 488 June 2023
Andrew_s wrote:z1bman wrote:https://www.ebay.ie/itm/KAWASAKI-Brake-Light-Indicator-Switch-OEM-28019-002-NEW-fits-KZ400-KZ440-Relay-/122297348052?hash=item1c797d6fd4
To my knowledge Andrew ,yes used a small one recently.think most of the Zed range use a similar unit though size differs.
PAULJAC47 wrote:Andrew_s wrote:z1bman wrote:https://www.ebay.ie/itm/KAWASAKI-Brake-Light-Indicator-Switch-OEM-28019-002-NEW-fits-KZ400-KZ440-Relay-/122297348052?hash=item1c797d6fd4
Thanks Paul - BTW, PM'd Keith O and waiting to hear back.
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
Aha, I wondered what that bit was for...
Well, the NOS Z400 brake light switch relay (28019-002) arrived this morning and I've just fitted it and it works fine; comes on with front and back brake and also flashes with the bulb removed so I'm a happy bunny and I've just ordered another one as a spare!
The fitting is a bit Heath Robinson until I sort out a bracket:
Andrew
Andrew
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
The bracket hangs under the RH coil mounting bolt on mine & gets in the way when you take the cam cover off. Let me know if you'd like a picture of the bracket?
cancunia wrote:The bracket hangs under the RH coil mounting bolt on mine & gets in the way when you take the cam cover off. Let me know if you'd like a picture of the bracket?
Thanks, that would be useful as I was wondering where/how it fitted.
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
