Float bowl pivot pins
I have just got a set of 28mm mikuni’s for my Z1B, they were gummed up solid, I have got the sliders moving freely, the floats were gummed up and wouldn’t move, with carb cleaner and acf50 I got them moving fairly well.
I remember reading a post a year or so back about someone breaking off the post that the float pivot is located in, I really don’t want to risk doing the same to my carbs. Does anyone have a method of getting these pins out safely.
Any suggestions greatly appreciated.
Jon
Jon
1975 Kawasaki Z1B
1979 Triumph Bonneville T140D
1969 BSA B25 Starfire
Re: Float bowl pivot pins
Use a spring loaded centre punch to push them out, sometimes called an automatic centre punch.
I've used a pin-punch and gentle to moderate taps with a small hammer. Maybe a bit of heat to encourage them to 'unstick' and / or a penetrating oil soaking. If they are well and truly stuck together you may need to get more forceful but always bear in mind that the alloy posts are a little fragile.
Present
Red '78 KZ - rebuilt from engine up
Other wheels - Couple of old Guzzi's
Past 1994 - 2010
Luminous Green '78 KZ import [BLE 656S]
Past 1994 - 2010
It wouldnt be a bad idea to fabricate a pin press that supports behind one of the posts with a g clamp type open claw!
Last set I did just used a very small drill bit and pushed them out. Maybe I was lucky they just fell out. If using force you will need to support rear of nearest post which you are pushing against. Use a centre punch slightly smaller than retaining pin.
Thanks chaps, I think I have a cunning plan, if it works I will keep you posted
1975 Kawasaki Z1B
They have always come out fairly easily for me once you figure out which end to drive from. Correct me if I’m wrong chaps but they are tapered on these carbs so they’ll only go back in one way round (?).
Boiling carbs in a 50/50 mix of lemon juice and water is remarkably effective at dissolving that brown gum if its really glued up. You could soak the pin holes in lemon juice (sounds a bit bizarre I know but it won’t do any harm if it doesn’t work) to see if it gets rid of any gum hiding in the holes. Heat is also your friend, though I’d be very gentle with it in a location like that.
Olly
Olly
Lemmy
Lemmy
Here is the brace I made out of an old Harley air filter cover, it worked a treat
1975 Kawasaki Z1B
Cleverest thing ive seen for a long time. Always a butt clenching moment taking those darned pins out, well done. Off to the shed to make one tomorrow.
Al wrote:Cleverest thing ive seen for a long time. Always a butt clenching moment taking those darned pins out, well done. Off to the shed to make one tomorrow.
Ginger Bear wrote:Al wrote:Cleverest thing ive seen for a long time. Always a butt clenching moment taking those darned pins out, well done. Off to the shed to make one tomorrow.
+2
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Mr Bump wrote:They have always come out fairly easily for me once you figure out which end to drive from. Correct me if I’m wrong chaps but they are tapered on these carbs so they’ll only go back in one way round (?)
That's what i thought too
Zedorset wrote:Here is the brace I made out of an old Harley air filter cover, it worked a treat
Best use of a Harley part ever
ZedHead wrote:Zedorset wrote:Here is the brace I made out of an old Harley air filter cover, it worked a treat
I don’t think it was ever going to be used for anything more useful.
1975 Kawasaki Z1B
Users browsing this forum: No registered users and 183 guests
