Bit of a strange one here chaps,,
Took the Z1b forks apart the other day and the two inards are different. The top one is correct i think, top tube bolt, spring and then the piston.
The bottom one i haven't a clue its totally different with a spacer and spring at the top, main spring, and then another spacer at the bottom, and the piston is different. Also the springs are different, same length but one has a tighter coil at the bottom.
Any ideas????.
Im on the look out for another correct slider if anyone has one, the main springs I'm thinking of replacing with progressive ones.
Fork springs
Re: Fork springs
Bottom one with the release valve looks correct. Cant help with the top one
Re: Fork springs
top one is correct for z1b the bottom one is an after market replacement valve kit but its assembled wrong in the photo
Re: Fork springs
Thanks for that, i kid you not but thats the order it came out.
Users browsing this forum: No registered users and 190 guests
