hello gents i finally got round to starting my gpz1100 after the winter lay up today and the left hand side exhaust is smoking quite a bit and it didn't before the lay up. any ideas what could be causing it the bike was on its centre stand all winter. i didn't bother taking it for a run as the battery decided to die as well.
many thanks in advance john
smoking exhaust
Re: smoking exhaust
possibly valve seals but i would ride it for a couple of hundred miles before you start to worry if it still has its fuel injection still fitted ? if it has been converted to carbs they would be the first port of call
Re: smoking exhaust
Black,blue or white smoke?
Re: smoking exhaust
Hi I have the same problem with my Z1B Been off the road for winter had carbs cleaned but I have Blue / White smoke from mine done about 150 miles on it but still smoking ??????
Z1B Happy Days Get the Z out and go for a Blast
Re: smoking exhaust
White/blue smoke = oil burning.
It's common when the bike has been stood for a while and it should clear up after a few miles.
If not it's most likely the stem seals on their way out.
Not a big problem until you start using more oil than petrol and you resemble one of the red arrows tearing down the high street.
Re: smoking exhaust
ha ha not that bad yet thanks very much for your replies.
Users browsing this forum: No registered users and 192 guests
