The only part of my front brake setup I haven't changed is the rotors. I'm using Harrison Billet callipers, which are great, and I was wondering if anyone knows of a Harrison disc that will go on in place of the standard?
Or any other recommendations, obviously.
Cheers!
Bike: z900 A4
A4: Change front discs?
1976 z900 A4 -- Now, with a little help from Wiseco and Steve Debben, it's a 1048 with rs34 flatsides
Re: A4: Change front discs?
If you are on 296mm discs EBC has floating replacements which are far better than the stock rotors
https://ebcbrakesdirect.com/motorcycle/ ... 1977/37404 (click on the discs tab)
You will get them at a decent price if you shop around although probably have to order them
I run floating discs and uprated calipers on mine and it stops very well
Thanks mate! Looks like an excellent option. I've asked Harrison if they do a disc - let's see.
I’m pretty sure Harrison don’t make a Zed floater - EBC made some custom offset discs for me a few years ago and they were very good to deal with.
Harrison do not make discs, they only make brake calipers.
EBC discs are good.
You could try Sunstar Discs - Saisei.com may be able to give you a pric
https://japan.webike.net/products/21184604.html
EBC discs are good.
Users browsing this forum: Google [Bot], HowieD and 208 guests
