can anyone tell me the distance between the front brake disc and the caliper mounts
the eliminator forks i fitted look exact in every way to the stock ones but my brake caliper mount bracket touches the disc when i tighten the bolts, i was thinking maybe because the eliminator has a different wheel size or i have the wrong calipers
thanks
1100R forks/brakes
Re: 1100R forks/brakes
are the caliper mounting brackets steel or aluminium ?
they are steel with 5 holes in them other than the mounting holes
if you have the steel carrier they are the correct calipers
From fork leg mounting lug to disc is 14mm (caliper removed for measurement ), caliper mounting bracket is 6.2mm thick, these are as close as I can get give or take .0*mm
Measurements were taken a couple of times so they're pretty accurate I hope
No longer searching.......
awesome, thanks so much for your help
Users browsing this forum: Bing [Bot], davejames and 153 guests
