Brake squealing
jonhunt
Brake squealing
#1 PostAuthor: jonhunt » Tue Jul 03, 2018 11:11 am
My front brakes squeal like a stuck pig. Tried copper slip to no avail pads are old but have life left. Maybe a change of pads to new ones would fix. Any thoughts?
Re: Brake squealing
#2 PostAuthor: deka » Tue Jul 03, 2018 9:42 pm
Could have smooth patches. I wo7ld change they are cheap enough so nothing to loose
kz900 c
bmwr1200gsa
955i daytona
Re: Brake squealing
#3 PostAuthor: PAULJAC47 » Tue Jul 03, 2018 10:10 pm
Jon try non sintered pads,always a problem at least you know they are working..
Taffus
Re: Brake squealing
#4 PostAuthor: Taffus » Tue Jul 03, 2018 10:16 pm
Just happy t see youre riding mate!
jonhunt
Re: Brake squealing
#5 PostAuthor: jonhunt » Fri Aug 17, 2018 6:31 am
Well, I have replaced the pads, the feeder pipes as one had started to leak, new lever ( old one had an oval hole) & new fluid. Short run, no squeak. Need a good ride out but been away for work.
Charlie
Re: Brake squealing
#6 PostAuthor: Charlie » Fri Aug 17, 2018 9:11 am
Brake squeal is always down to the pads vibrating in the caliper.
Usually caused by old pads, sticking pistons, occasionally a warped disc. It's nearly always a simple fix.
Re: Brake squealing
#7 PostAuthor: chrisu » Fri Aug 17, 2018 10:38 am
Taffus wrote:Just happy to see youre riding mate!
^^^This
jonhunt
Re: Brake squealing
#8 PostAuthor: jonhunt » Wed Aug 29, 2018 9:40 pm
Done silence reigns
