hi
just got my 1977 z1000 a1 an upon trying to adjust the carbs with morgan carb balancer two of the screw adjusters at the top of the slides are damaged,the screw slot is worn and i cant properly adjust them.
does any one know either part number or supplier of replacements ,all my searches have proved fruitless
thanks
john
z1000 a1 mikuni carb adjuster
- warren3200gt
Re: z1000 a1 mikuni carb adjuster
You could give allens performance a ring, all they do is carb and fuel line parts.
http://www.allensperformance.co.uk/shop/
PUM 488 June 2023
thanks for quick response , will give them a try
try john browse in wrexham
z1bman wrote:try john browse in wrexham
+1
Part number is 16046-012. There are a few from the states on ebay for stupid money.
This has happened quite a bit, on one set i had i cut the slot deeper and made the screwdriver narrower to enable me to do the job, worked fine not perfect, but you never see them unless making adjustments.
Users browsing this forum: Bing [Bot] and 115 guests
