Hi John
good to see you're back and that you've started with the rebuilt!
Looks good to me, keep us updated with more pictures! We all like that!
Let the good times roll !
clocks
Re: clocks
- new poster
Rebuild
Hi Philippe. I will post pictures as i go along with the build, but i only get Saturdays to work in the garage, got a prblem as i have an oil leak getting onto the stator. , so thats a step backwards.
Re: clocks
Hi John
what do you mean by an oil leak on the stator? Do you mean the alternator? The stator and the rotor run in oil, it comes from the engine and it's supposed to be like that. As long as the oil stays inside the engine it's OK.
Re: Steering lock
john richardson wrote:Hi i need some help again , can any one tell me how to remove the steering lock from thr Z1R im rebuilding the only problem is the bike came with no keys
Just to let you know that if you get a replacement steering lock from Z-Power, the rivet that retains the swivel plate is not long enough to retain it, it will fall out so beware. If you can buy a genuine K rivet that would be much better.
I know as I've just done two Z1R-TC steering locks.
Regards Will
Kawasaki GPz750T, Kawasaki ZRX1100R, Kawasaki GPZ1000RX, H**** VF1000RG Rothmans, H**** VF500F2F, H**** CB1100RD, Suzuki GSX1100EFE, H**** XL125K2
Users browsing this forum: skinnyZED and 210 guests
