Speedo cable
Speedo cable
Just bought a new cable for my Z1a. At 33” it’s a tight fit. There is a small radius bend at the drive end which doesn’t look right This is the size I see as correct on several vendors. The one I replaced was 37”. Front end is std
Re: Speedo cable
you have wrong one, 34" is for a z900, yours should be 37"
Re: Speedo cable
All zeds 73-77 Z1 - Z1000A1 & Z1000D1 use part number 54001-040 which is 84cm (33") long.
Later Z1000 A2/3 and Z650 use part number 54001-1002 which Is 94cm (37")
Re: Speedo cable
Can the drive be fitted in more than one position? That’s the only variable I can think of. The forks a sitting in the correct position. I’ll stick some pics up at the weekend. Cable bends at about 80 degrees from horizontal
Bike originally had calipers behind forks. I changed it back to standard twenty years ago
No reflection Saisei. Z Power quote 33 as well.
There’s a variety of offers in e bay. Some are 33 and some are 37
Seems there is some confusion in the marketplace
Re: Speedo cable
I have heard that turning the fork legs to mount the calipers behind can force the speedo drive downwards, hence a longer cable is needed. Since you have turned them back the drive should go back into the correct horizontal position.
Hope this helps.
Dave
Hope this helps.
Dave
Users browsing this forum: No registered users and 84 guests
