Reg/Rec Failure Symptoms
Posted: Sun Aug 19, 2018 1:31 pm
As Above, i have a combined reg/rec, what are the symptoms if its failing.
Out of nowhere i have a flat spot around 4k , i can ride through it, but it feels like it running out of fuel. I have had the carbs off and they were clean, fuel tap - Pingle - clean and flows as it should, no other work to the bike over the winter except oil and filter change. Scratching my head with this one!!
Any advice appreciated
foz
foz
