Those of you that have helped me in the past will know i have been reluctant to move with the times with my restore but I'm starting to question some of my desertions.
So should i stick with the traditional points or should i for all the right reasons invest in electronic ignition?
If yes then what is the must have product?
Points or Electronic ignition
Bike now finished what a joy!
Re: Points or Electronic ignition
dnya s would be my choice
is that a straight swap out of points. All my coils and leads are new.
The only real benefit of changing to electronic ignition is lack of maintenance needed.
If you decide to change, Dyna S would be my recommendation too. Very straightforward to swap out and will work with standard coils.
there is even a 'how to ' on the site. very easy to do. Just swap points plate, connect and time up.
http://z1ownersclub.co.uk/phpBB3/viewtopic.php?f=4&t=2588&p=22551&hilit=dyna#p22551
- chrispyduck
Fat girls are like M****s, they are fun to ride, you just don`t want your mates to see you.
For Dyna s - Main advantage - as has been said - is lack of maintenance.
Main disadvantage is if it goes wrong - employing a 'get you home' fix will not be easy.
Having said that - Both the original points and the Dyna s are known to be fairly trouble free.
I have dyna coils and the original points system on both my bikes & never had an issue in this area.
pays your money & takes your choice !
010
- warren3200gt
Run oem points and condensors on all my bikes without trouble or excessive maintenance. They worked fine then and continue to do so now.
PUM 488 June 2023
Users browsing this forum: No registered users and 222 guests
