Spark Plug Cap
Spark Plug Cap
Think I need to replace a cap on my 79 Z1000 A2 so will do all 4 I think - If I replace like for like with NGK caps, which ones do I need and are the inner/outer ones the same ? Also are there any tips on fitting ie do you simply unscrew the old and screw on the new ones ? Thanks all.
Re: Spark Plug Cap
these are what you need https://www.ebay.co.uk/itm/NGK-Spark-Pl ... SwQiBZ27sL
Re: Spark Plug Cap
Thanks - These state resistor type - Are they ok with non resistor NGK B8ES plugs ?
Re: Spark Plug Cap
should be the original Kawasaki plug cap had a resister
- warren3200gt
Re: Spark Plug Cap
You need either no resistor on cap and plug or either one to have a resistor but not both.
PUM 488 June 2023
Re: Spark Plug Cap
If you are replacing the plugs be certain to get genuine Ngk loads of copies out there,Denso are a better bet...
Re: Spark Plug Cap
Warren never heard of resistor on one or other before , but must admit ngkb8es used to go down a lot on startup on my old z900 , one wet , useless , wonder if that was the prob , But it sounds like the combination spoke of here is wrong
- warren3200gt
Re: Spark Plug Cap
Not sure why we bother with any resistors, either plugs or caps, these days. As far as I cant tell, the only reason to run resistors anywhere in that circuit is so it doesn't interfer with the old analog tv signals. As they are all digital now I dont see any benifit. I prefer the look of ngk non resistor black caps and run non resistor denso plugs. No resistors at all means one thing less to go wrong!
PUM 488 June 2023
Re: Spark Plug Cap
Lol , luckily , i bought up a few of them black cap Ngk non resistor ones a while ago
Users browsing this forum: No registered users and 197 guests
