Sorry if this isn't in the correct forum, hope the Admin will correct me if so.
I've had a bead blaster for a number of years and have got use to keeping the bikes under covers due to the dust. But now the dust piles are beginning to get a little hilly, and I'm getting a little worried about the finer particles .
Anyone got suggestions for a good extractor?
Bead Blaster Extractor
Kwaki lover - Z1000R2, ZX9R F1P, GPz1100B1, 350 S2 and a brace of 500 H1's. For fun I've got a couple of LC's too yahooooo
Re: Bead Blaster Extractor
when my sons extractor packed up i used a wet & dry vacuum from wickes only about £35 did the job better than the industrial one he had
Might have to have a rethink as I dismissed the wet and dry vacs as the dust is still abrasive, hence my reason for getting that stuff away from the engines and the paintwork. At £35 It's worth a punt.
Thanks z1bman
Thanks z1bman
my sons blaster was used every day & he used the finest grit which i thought would ruin the motor but was still going when he sold the blaster with the vacuum to a friend of mine & he still uses it & the filter in them is very good quality
https://www.wickes.co.uk/Wickes-Wet+Dry ... GwodW_wObQ
along the same lines I just uses old give away hovers and run them till the are dead normally a good few years of shed working which give you time to find the next one to have as stand by
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
along with some lesser makes
Z1300 A1,
KE175b, KE175F
Thanks everyone. I've invested in a Wickes wet and dry vac and preparing for a weekend blast session on yet another Kwaki 500 triple . . . . definitely addicted.
Users browsing this forum: Bing [Bot] and 71 guests
