Rear shocks
Rear shocks
Would anyone know if ZRX1100 rear shocks will fit a Gpz1100b1. Same length??
I was thinking of buying these if they will fit:
https://www.ebay.co.uk/itm/Ohlins-pair- ... Blackline-Hodna-CB1300-/11283038546
Apparently Ohlins HO963, as listed above, fits various bikes including CB1300 and ZRX1100
Re: Rear shocks
GONE !
Kawasaki GPz750T, Kawasaki ZRX1100R, Kawasaki GPZ1000RX, H**** VF1000RG Rothmans, H**** VF500F2F, H**** CB1100RD, Suzuki GSX1100EFE, H**** XL125K2
Re: Rear shocks
That does not answer the question though
Re: Rear shocks
ZRX shocks are 365mm centres. 12mm eye at the top, 10mm eye at the bottom. Reservoir goes to the top
ZRX1200 shox have a plastic cover inside the shock body, 1100 don't. That aside, they are pretty much the same items
The shocks will fit pretty much any Zed - it would only be the length that altered. They fit my modified Z650 OK but are longer (in my case that isn't an issue)
I have no idea how long GPZ shocks though
Re: Rear shocks
Thank you kindly sir
Re: Rear shocks
https://www.saisei-europe.com/Shop/Prod ... oad-track2
I sold these to Lee Jackson a couple of years ago to fit on his ELR project. If I remember correctly he used a ZRX swing arm.
Ohlins do not list anything for GPZ1100 B1 but I would guess they would fit.
If you want further clarification I would be happy to ask my technical contact at Ohlins on your behalf
Re: Rear shocks
I’m sure I’ll be able to wrestle them on somehow.
Re: Rear shocks
Thanks saisei. Didn’t realise you sold them.
Re: Rear shocks
1981 J1 shocks are 350mm (347 to be picky) centre eye to centre eye.
There is a slight peculiarity with the J1 shocks. Its bottom eye is spaced to one side and its supposed to be like it.
It is to clear the 630 chain and chainguard.
It may be possible that the above also applies to the 1981 B1, however if you are changing the swingarm then it all becomes academic.
Re: Rear shocks
scott wrote:Thanks saisei. Didn’t realise you sold them.
Your welcome Scott. I have been an Ohlins dealer for nearly 5 years. Information is free
Re: Rear shocks
here you go scott zrx shocks on my b2 but i had to alter chain guard a smidge.
Re: Rear shocks
Very nice bike mate
Re: Rear shocks
Scott. If you end up buying a set and needs some new KYB decals then let me know as I sell these in either red or gold.
https://www.ebay.co.uk/itm/KAWASAKI-ZRX ... :rk:2:pf:0
Regards Will
Regards Will
Users browsing this forum: No registered users and 336 guests
