hi all fitted new valve guides and had valves cut and relapped in and i've come to check valve clearances and noticed my cams are andrews.going back to standard bore and pistons can these be used or is it best to use standard cams.
cheers ogre
z1 cams
Re: z1 cams
hi all just checked cams says x2 on the end don't wanna build it up to find that these are only good for big bore engines some help would be appreciated.
cheers
cheers
Re: z1 cams
Specs for the Andrews X2 cams are in the link below..
They are fairly mild, no need for a big bore and will run with stock valve springs.
http://www.andrewsproducts.com/files/assets/KZ900-1.pdf
Re: z1 cams
I have a set of X2 cams. Bought them because they are a mild street cam, you shouldn't have any issues with them in a non-tuned bike.
Re: z1 cams
Got 2X in one of my Zeds work well
Users browsing this forum: No registered users and 253 guests
