z1000 Torque arm
- steve bowdler
z1000 Torque arm
Hi is there any difference between the torque arm on the z1000A1/2 and the B1/2 models ? , I know the swing arm is shorter !
Re: z1000 Torque arm
yes its shorter & different part no
- steve bowdler
Ok thanks , then could someone post some measurements of a z1000 a1/2 torque arm please
steve bowdler wrote:Ok thanks , then could someone post some measurements of a z1000 a1/2 torque arm please
370mm overall
340mm centre bolt holes
Do you need one Steve?
- steve bowdler
not sure yet Chris , I believe I have the shorter z1000 b2 swing arm but think I have the standard torque arm ?? will re measure this weekend
- 8 Valve Mark
I've got a spare ltd one if you want one steve.i can measure it if you need one. m
- steve bowdler
Hi, yes if you could measure it please
- 8 Valve Mark
350mm,hole centres@ 320mm
Users browsing this forum: skinnyZED and 199 guests
