vm28ss
- 8 Valve Mark
vm28ss
i recently bought some pumper carbs which came with no air screws or springs!!!. does anyone know how long they should be?? (screws +springs) probably the same as non-pump vm28 but I'd like to be sure before ending up with wrong ones. cheers in advance.. m
- warren3200gt
Re: vm28ss
give the guys at Allens performance a ring to be sure. They will also have the parts you need.
http://www.allensperformance.co.uk/shop/
PUM 488 June 2023
- 8 Valve Mark
Re: vm28ss
thanks Warren, I'll check the link, i have possibly sourced some already, but the seller has various lengths. I'm aiming to test run the carbs then possibly fit keyster kits if required. cheers m
Re: vm28ss
Mark,
I've got a set of 28mm pumpers from a 1000. I can check them and let you know if you'd like?
- 8 Valve Mark
Re: vm28ss
yes please nigel the top of the thread to the tip and the spring length would be much appreciated. thank you very large!! mark
Re: vm28ss
The ones fitted seem to be quite a way down the passage way so I'm wondering of not original or correct. However, they came off a running bike which had just been setup on the dyno...
24mm Total length
19mm tip to bottom of thread
I forget to measure thew spring length, but will do.
Hope this helps
24mm Total length
Hope this helps
- 8 Valve Mark
Re: vm28ss
that's great nigel, super rapid too..i hope you counted the turns on yours? cheers matey. m
Re: vm28ss
8 Valve Mark wrote:that's great nigel, super rapid too..i hope you counted the turns on yours? cheers matey. m
No worries, I'll need top remember to measure the spring length too..
- 8 Valve Mark
Re: vm28ss
no rush mate,re springs; just whenever, if you can be bothered, screws are hopefully not an issue now thanks to your help.. cheers mark.
