Offset gearbox sprocket
scott
Junior Section leader
Re: Offset gearbox sprocket
#16 PostAuthor: scott » Tue Jan 22, 2019 9:30 am
Thanks Math, Talon state over a £100 for the sprocket :shock:
garyd
#17 PostAuthor: garyd » Tue Jan 22, 2019 6:00 pm
how many teeth on the gearbox spline?
I have a couple of unused ones but don't know if they are kickstart or J type.
scott
#18 PostAuthor: scott » Tue Jan 22, 2019 6:29 pm
Gary, there are 12.
Talon are £100+
B+C Express don’t supply them.
VVM Racing will do them for 68 euros, I suspect there will be postage on top.
Mathh
#19 PostAuthor: Mathh » Tue Jan 22, 2019 7:29 pm
Mathh wrote:VVM racing in the Netherlands make offset sprockets on request. I just ordered a 530 19T hardened with 250mm offset for 85 euros including postage.
Forgot to mention that it is with a collar for an outrigger bearing (52mm)
#20 PostAuthor: Ginger Bear » Tue Jan 22, 2019 7:31 pm
Scott, it may be worth seeing if anyone else needs one, as the prices will tumble with Talon, even with an order of just two or three.
Piggy organised a decent sized 'batch' for the kickstart motors a few years back, the savings were substantial.
# 104
#21 PostAuthor: zed1015 » Tue Jan 22, 2019 7:50 pm
Ginger Bear wrote:Scott, it may be worth seeing if anyone else needs one, as the prices will tumble with Talon, even with an order of just two or three.
Mark got the price down to £45 each when buying ten BUT you may as well just look on EBAY and get one from GRUMPY 1260 to save all the waiting.
GPZ1100 B - 5/8 offset ( also does 3/8 ).
16 to 19 teeth,
530 pitch.
66 Quid.
https://www.ebay.co.uk/itm/Kawasaki-GPZ ... :rk:6:pf:0
JOB DONE.
#22 PostAuthor: Pigford » Tue Jan 22, 2019 8:27 pm
16 to 19 teeth,
530 pitch.
66 Quid.
JOB DONE.
Blimey - is that all they were...... just offered one to Scott for £75 delivered :oops: my bad - I'll do it for £59 delivered :lol:
scott
#23 PostAuthor: scott » Tue Jan 22, 2019 8:50 pm
The z900/1000 share the same sized shaft as Gpz, yes?
#24 PostAuthor: Al » Tue Jan 22, 2019 9:59 pm
No fraid not, 900 / early 1000's have a Z13 pattern (13 tooth shaft).
J series motors have a Z12 pattern (12 tooth shaft)
#25 PostAuthor: Ginger Bear » Tue Jan 22, 2019 10:00 pm
scott wrote:The z900/1000 share the same sized shaft as Gpz, yes?
No.
# 104
scott
#26 PostAuthor: scott » Tue Jan 22, 2019 10:03 pm
Ok, the ones piggy has are for z900/1000. Thanks for answering that Al. I’ll get a Grumpy one.
scott
#27 PostAuthor: scott » Wed Jan 23, 2019 10:35 am
Guys, what bearing do i fit in to the collar.....does anyone have an image for this bearing fitted to the collar?
#28 PostAuthor: zed1015 » Wed Jan 23, 2019 11:23 am
scott wrote:Guys, what bearing do i fit in to the collar.....does anyone have an image for this bearing fitted to the collar?
If you are buying the one from the GRUMPY ebay link it doesn't have a bearing nose so no need for a bearing.
scott
#29 PostAuthor: scott » Wed Jan 23, 2019 12:51 pm
The VVM Racing one can be supplied with the collar for the bearing, so would like to consider that option to. As you said Rob the Grumpy one has no provision for the bearing. I gather the bearing provides some support but would like to see some pics of how the bearing fits etc. VVM have sent me an image of the sprocket that i THINK i want. If anyone can provide an image of a bearing fitted then it may confirm what i'm looking at with VVM.
#30 PostAuthor: zed1015 » Wed Jan 23, 2019 4:25 pm
This is an offset with bearing nose fitted.
A 52mm 6304 bearing slips in after it's bolted up.
The bearing has a groove and clip on it's outer to stop the bearing going in too far or floating about.
This is an outrigger support that you will need which you can make or buy from D&G etc.
The four bolts hold an ally stub which simply slots into the centre of the bearing which is usually 20mm.
It also holds the clutch mech and supports the gearchange shaft.
This is a pic of the inside of the outrigger plate clearly showing support stub with the sprocket and bearing slotted on.
Unless you are planning loads of power you don't really need this and although running any offset will naturally put extra load on the output shaft bearing and shorten its life this is probably negligible on a stock or mildly tuned motor.
Here is the bearing and an ebay link to the cheapest.
https://www.ebay.co.uk/itm/Major-Brande ... SwSn1cRn4x
