Starter clutch swap between year models
Hi can't find info by searching topics. So does anyone know if there is any difference between starter clutches across the years. I need a complete clutch including the damper spacer for an early Z1000 with the small rotor that sits inside the alternator ring. Thanks David
Re: Starter clutch swap between year models
As long as your thou doesn't have a rotor keyway all the small type rotors and clutches will fit from any Z900 to Z1000.
If it does have a keyway then you must use a keyed rotor as the smaller 8mm bolt can't stop the rotor spinning on it's own.
Clutches are the same on all small rotors.
Thanks zed
The engine came with a rotor fitted but no starter clutch. There's one on ebay listed as KZ1100 Z1100A Z1000J GPZ1100B1 Shaft 1981-1983 Starter Clutch. Does anyone know if this will fit.
Thanks David
Thanks David
given the Mk2 ones are different i'd doubt the even later 1100 one would fit...
dbee wrote:Thanks zed
Thanks David
No! Only 1973 Z1's to around 1979 Z1R D1 kickstart equipped bikes (round cam cover) will fit.
The later 1015 MK2/ST Kicker ( square cam cover) and all later GPZ/J style 1000's and 1100's have a bigger taper and dished type rotors.
Thanks everyone for replying
Not sure if i'm explaining correctly but I dont need the rotor as I know they wont fit. What i'm trying to find out is will the later starter clutch from a later model (just the large gear, needle bearing and roller housing and thrust washers) bolt up to my small rotor. Looking at the part numbers on Bikebandit they're the same.
Thanks again David
Thanks again David
- ZedHead
dbee wrote:Thanks everyone for replying
Thanks again David
I think I have what you need, PM sent.
Mark.
Mark.
Thanks again David
I fully understood the question and as stated only the earlier clutch assembly will fit.
Some individual parts are common such as the rollers etc throughout the range but the larger diameter taper of the later cranks also means that the starter clutch center, needle bearing and thrust washers etc are also larger.
Thanks zed
you are right went around to D&K my local breakers armed with the info you gave. And they got a selection of starter clutches from various years and models out for me to compare. The early starter clutch gear roller bearing inner measurement was 22mm while the later Z1000 roller bearing inner measurement was 25mm. So I had a Starter clutch off a Z1B for £52 fits perfectly.
So thanks again everyone.
David
David
Users browsing this forum: No registered users and 171 guests
