Forks knocking at full extension/rebound
#1 PostAuthor: warren3200gt » Sun Feb 17, 2019 6:23 pm
Before I strip both legs again anyone got an idea what would cause the forks to knock, or over extend causing a knock, when I go over an uneven surface. Compression is fine. So trying to get my head around what to look for. Forks are z1b
PUM 488 June 2023
Re: Forks knocking at full extension/rebound
#2 PostAuthor: Pigford » Sun Feb 17, 2019 7:00 pm
Double check your engine mounts (front especially) are tight :!:
I had similar situation which I thought was the forks...….. but turned out to be loose front engine bolt knocking.
#3 PostAuthor: warren3200gt » Sun Feb 17, 2019 7:19 pm
Nice lateral thinking but I dont think thats it as it had a4 forks on previously and they were fine., but easy enough to check so I will thanks.
PUM 488 June 2023
#4 PostAuthor: Al » Sun Feb 17, 2019 10:11 pm
It could be the order of assembly. J forks (similar) are very easy to get the 'top out spring' in the wrong place and have it mashed to bits by the bottom of the fork inner stantion.
marmck
#5 PostAuthor: marmck » Sun Feb 17, 2019 11:12 pm
Does your steering head need adjusting ?
#6 PostAuthor: warren3200gt » Mon Feb 18, 2019 8:40 am
marmck wrote:Does your steering head need adjusting ?
No not head adjustment. Im sure its something to do with the fork internals, like an air lock or the return valves not operating as they should. Could be not enough oil but they have 170ml as per the service manual but that doesn't sound like a lot?
PUM 488 June 2023
#7 PostAuthor: warren3200gt » Mon Feb 18, 2019 8:47 am
Al wrote:It could be the order of assembly. J forks (similar) are very easy to get the 'top out spring' in the wrong place and have it mashed to bits by the bottom of the fork inner stantion.
Assemble as per the parts list diagram. Guess Im just going to have to strip them again but unless I find something obvious I did then I know I'll re assemble them exactly as I did first time. :?:
PUM 488 June 2023
#8 PostAuthor: ADRIAN H » Mon Feb 18, 2019 8:52 am
Strip them and post a picture.
#9 PostAuthor: warren3200gt » Mon Feb 18, 2019 9:52 am
Yep, will do. Not going to get to until later in the week though the missus has decided the hall needs redecorating, no sense of priorities these women. :roll:
PUM 488 June 2023
#10 PostAuthor: warren3200gt » Mon Feb 18, 2019 3:15 pm
Quick thought, is it better to fill the oil with the forks fully compressed, ie wheel on the ground or fully extended ie wheel off the ground. Or does it not matter? Thinking about expelling any trapped air?
PUM 488 June 2023
Julian_Boolean
#11 PostAuthor: Julian_Boolean » Mon Feb 18, 2019 3:28 pm
warren3200gt wrote:Quick thought, is it better to fill the oil with the forks fully compressed, ie wheel on the ground or fully extended ie wheel off the ground. Or does it not matter? Thinking about expelling any trapped air?
It doesn't matter, any trapped air will make it's way to the top pretty quickly.
As for the knocking, worn bushes, loose damper rod or misassembly, but it could just be something loose.
#12 PostAuthor: warren3200gt » Sun Feb 24, 2019 11:50 am
Got the forks disassembled and now a bit confused! The first pic is of complete fork parts. The second of the damper ass that was in them. They look very lightweight for a 900. So don't think they are the correct ones.
Had a route in the parts bin and came up with some that look much more like the correct bits, the third pic. Question is, are they? and there is a red collar missing from one of them. What is that supposed to do and is it necessary? I can guess the answer and where can I get one or would one turned from nylon suffice? Having had a close look at the pic on the same assembly there appears to be a seat washer missing for the little weak spring also.
PUM 488 June 2023
#13 PostAuthor: warren3200gt » Sun Feb 24, 2019 4:42 pm
That seems to have sorted it. Made the missing bits and fitted the ones in pic three. Front end is a lot stiffer which I like and no knocks anymore. Happy days although begs the question what are the original one from?
PUM 488 June 2023
#14 PostAuthor: Philippe » Sun Feb 24, 2019 5:20 pm
Hi Warren
if they're aluminium they could be from a Z1 front fork, if i'm correct those aluminium tubes were replaced with steel tubing from the Z1a onwards.
#15 PostAuthor: warren3200gt » Sun Feb 24, 2019 6:07 pm
Ok thanks Philippe. No good to me, anyone need them for a Z1?
PUM 488 June 2023
Users browsing this forum: Bing [Bot] and 97 guests
