J/R/GPz engine mounts
On the J/R/GPz (and possibly others) the rubber engine mounts have metal / rubber washer things that go outside the rubber mounts at the front. In the manual it says to stick them on with adhesive of some sort, can anyone recommend a product?
- 8 Valve Mark
Re: J/R/GPz engine mounts
anything like superglue or strong glue is ok chris .the shop manual says 'use a suitable bonding agent' nothing specific. m
No clue-least I'm consistant
Superglue can melt some rubbers- I found out the hard way
Araldite is my go to glue
Good luck
Good luck
I use Loctite SI 5980 to stick literally everything on my bike. Sometimes comes in useful round the house too.
https://www.halfords.com/workshop-tools ... ge-sealant
Just need to check the date code stamped on the crimped end of the tube itself because its only any good for six months and they dont seem to sell it quickly enough!!
Al wrote:I use Loctite SI 5980 to stick literally everything on my bike. Sometimes comes in useful round the house too.
Good tip...
- 8 Valve Mark
all above recommendations are probably equally valid, but double sided tape will do the same job, as it only has to keep the rubbers in place while you fuck about, trying to get the engine bolts back in place.polygrip false tooth glue would probably be ample.. fuckthake..
Users browsing this forum: No registered users and 322 guests
