Clock mounting rubbers
I have just removed my clocks for a refurb and was greeted by this...
Missing bulbs (thought it was a bit dim on evening rides home). Extra foam of varying densities.
The amount of botched crap I have uncovered on something that looks ok on face-value is astounding!
My question is; which rubber mounts are correct for a Z1000A2 - Saisei and Z-power both have two types!?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
Re: Clock mounting rubbers
Thanks, but just below there are these...
https://www.cybike.co.uk/Shop/Products/ ... unting-set
What's the difference between a meter mounting damper set and a clock bracket mounting set?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
one set mounts the complete bracket to the bike, the other set mounts the individual gauges to the bracket
the link Z1Bman listed mounts the gauges to the bracket
the one you posted mounts the complete bracket assy to the bike
Great, many thanks to you both.
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
I have used the Cybike clock mount rubbers and they fit A1
If you are not powder coating the bracket i would leave the foam as it is
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
1976 KZ1000a1, Red
BigZCas wrote:I have used the Cybike clock mount rubbers and they fit A1
Cheers Cas, I plan to get a set from Dave although the foam is in a bad way and disintegrating rapidly with every touch. Was wondering if it might be worth cutting out some correct shapes from 'funky foam' and resticking?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
I've tried cutting foam draft excluder in the past to save money, very tricky
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
What about these... https://www.littlecraftybugs.co.uk/10-b ... uares.html
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
One of the guys on here did some from sticky back foam for me I photo copied them as templates so print this full size a4 and use them as a template.
Many thanks for that, Ive gone and bought some 5mm sticky back foam from Ebay, a 10mm hole punch and a scalpel today- total around £15. You'd think there would be a specific part what with all the Zed specialists out there these days!
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
- 8 Valve Mark
go for it gonzo, a bit of blue peter inventiveness should work fine!! make sure all adults have left the room before you start though. m
Godamit, you're right... I can do this!
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
- Regular Poster
KWACKERZ1 wrote:One of the guys on here did some from sticky back foam for me I photo copied them as templates so print this full size a4 and use them as a template.
I'd appreciate some advice as I'm doing this job on my Z1000A1. Are the steel dowels supposed to bottom out when the clocks are tightened up?
Thanks Roger
1976 KZ1000A1, 1981 KZ1100 Shaft+Steib TR500 sidecar (ongoing), 1942 Motoguzzi 600U, 1948 Moto Guzzi GTV, 1952 Moto Guzzi Ercole (in bits), 1953 Nimbus, 1986 Moto Guzzi V65 Lario (in need of TLC), 1988 Moto Guzzi Mk V Le Mans
Users browsing this forum: Bing [Bot] and 100 guests
