Z1R import MOT requirements
Z1R delivered, all ok. Quite pleased as i but in some fresh fuel and she started first time. Idles and revs fine, checked everything over and all is good.
I need to get an MOT for the registration, and whilst checking the lights noticed some strange. When i put on the headlight the front indicators also come on!, they stay on and also flash when selected!.
Before i start cutting wires, is this normal for US spec bikes, and also would it be an MOT failure here in UK. To avoid cutting wires and to speed up registration I guess i could get a daytime MOT???.
Also are there any other things in particular i need to change, eg. do i need to replace the headlight?
Rob
paid up member
Re: Z1R import MOT requirements
Hi Rob
You would have to remove the indicators and tape over the switch as I believe if they are fitted they must work
May be a Yankee wiring diagram would show you if there was an extra supply wire you could just un plug to stop the constant supply?
Because of the year you can just remove them I think later bikes have to have them fitted and working but not sure of the cut off year
Gus
Gus
"Set the GRINDER on it"
rpeters wrote:IMG_1337.jpgIMG_1336.jpg
Rob
That is normal for USA bikes. Is a left hand drive headlight you can just use black tape to pass.
Just disconnect the blue side light connections to the indicators, just behind the fairing.
They have long thin terminals and you should be able to just get in without removing the fairing.
Kawasaki GPz750T, Kawasaki ZRX1100R, Kawasaki GPZ1000RX, H**** VF1000RG Rothmans, H**** VF500F2F, H**** CB1100RD, Suzuki GSX1100EFE, H**** XL125K2
rpeters wrote:I guess it’s down to an understanding MOT guy
disconnect that filament and dont tell him he will never know
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
