Bought a set of brake pipes ages ago when I was collecting parts. Now at the point of fitting the dual set up on the a4 and notice one does not look correct picture below"... anyone have an idea what this is for The other one appears correct for the right side but the left one below (Speedo drive side) does not
Brake pipe
Brake pipe
GPZ1100 A1 zrx1100 gsa1200
Re: Brake pipe
Here they are side by side Or is this correct ? It dose not look right
Re: Brake pipe
the one on the right is correct for the l/h side but the left hand one is not for the z1.z900/ z1000
Re: Brake pipe
I bought them as a set but cannot remember from where but they obviously messed up
- 8 Valve Mark
Re: Brake pipe
why not just bend the wrong un into shape, snip one end off and re-flare it to suit?
Re: Brake pipe
It looks like it could be for rear mounting caliper that has found its way onto the wrong bin. I checked your orders and you can eliminate me from your list of suspects
Re: Brake pipe
ZedHead wrote:It looks like it could be for rear mounting caliper that has found its way onto the wrong bin. I checked your orders and you can eliminate me from your list of suspects
Ha ha.
Users browsing this forum: wheelysteve and 77 guests
