Tank screws
- warren3200gt
Re: Tank screws
Parts manual lists them as
SCREW, coutersunk head 3mm thread x6mm long.
PUM 488 June 2023
- 8 Valve Mark
Re: Tank screws
zpower sell them..
Re: Tank screws
they do Mark but they are a £1 for 4 + vat which is fine and then £3.50 for postage, which tbh is a but much and i dont need anything else at the moment
GPZ1100 A1 zrx1100 gsa1200
Re: Tank screws
The screw is 221C0306 which is only £0.14 each from Kawasaki UK.
I use Cradley Heath and postage is free
Kwaki lover - Z1000R2, ZX9R F1P, GPz1100B1, 350 S2 and a brace of 500 H1's. For fun I've got a couple of LC's too yahooooo
Re: Tank screws
Re: Tank screws
Thanks Mike ordered and free postage result plus standard equipment :-)
Re: Tank screws
Re: Tank screws
How many do you need?
Re: Tank screws
are they the Same for all Z1000 Modles as i will need about 7 plus sets for all sorts of models
at 14p if they are all the same i will buy 20 units in one hit and really push the boat out
anyone know what the thred pitch mite be so i can find a tap as I have some that need to be sorted before paint
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
along with some lesser makes
Z1300 A1,
KE175b, KE175F
Re: Tank screws
I imagine they'd be the same M3 thread, if it's an M3 x 6 csk - but accept I may be wrong. Could check on CMSNL.
Just checked the screws I bought for the Gpz1100B1 and the Z1000R2 last week, which are the same for those two models and the same part number as the Z900 A4 - 221C0306 which is superceded by 221AB0306
Re: Tank screws
fab info thank you
Z1300 A1,
KE175b, KE175F
Z1300 A1,
KE175b, KE175F
Re: Tank screws
And when you use them.........
Make sure that you check that they aren't too long, it is possible to screw through the badge, through the mounting bar and perforate the tank-that's not a good outcome, be careful
Re: Tank screws
local fastener place they would be peanuts.....
and yes , I am a tight git!
Re: Tank screws
trikerdrew wrote:local fastener place they would be peanuts.....
then they would be Phillips and not Japanise Industry Standaed
JIS cruciform driver sizes[1]
Driver
size Machine Screw
Size
#000
#00
#0
#1 M2, M2.2, M 2.5
#2 M3, M3.5, M4, M4.5, M5
#3 M6, M8
The JIS B 1012 is commonly found in Japanese equipment. It looks like a Phillips screw, but is designed not to cam out and will therefore be damaged by a Phillips screwdriver if it is too tight. Heads are usually identifiable by a single dot or an "X" to one side of the cross slot.[29]
Specific "JIS" standardized cruciform-blade screwdrivers are available for this type of screw.
Z1300 A1,
KE175b, KE175F
Z1300 A1,
KE175b, KE175F
Users browsing this forum: No registered users and 117 guests
