Minor details z650
Minor details z650
Gents
Nearing completion on the rebuild of the z650. The red paintwork is growing on me now that I have polished and waxed it and fitted the nice shiny bits. Pics coming soon....In the meanwhile, a couple of questions if I may...
First pic shows the clock surround. As can be seen, it is pock-marked with surface corrosion. Incidentally, it is the original enamel? paintwork but I have clearly replaced the pods with chrome. The question is whether to leave as is and keep the original paintwork, or rub it down and respray. If the latter, and I am tending towards that as it looks somewhat incongruous against the rest of the now very nice looking bike, then respray with what? I have black enamel - which I think will be close, or gloss black.
Second pic shows the outlet fuel pipe connection from the petcock to the carbs. You can see the groove. Should there be an o-ring here? If so, it may still be in the petcock body I guess.......
1946 Ariel VB600, 1966 Triumph Bonneville, 1975 400/4, 1979 Z650
Re: Minor details z650
Yes there should be an o ring
- warren3200gt
Originally the clocks where satin black. Simonez tough paint satin black is the go to for original match.
Post a pic ot your fuel tap Oggers. Dont think you have the gravity type off a b1 like below. The feed pipe doesn't come out of these.
Or if thats a pic of the other carb end it should be a T piece.
PUM 488 June 2023
Warren
Correct...I don't have a (direct) gravity feed. It's vacuum controlled. Red pipe connects to carbs and provides vacuum on a diaphragm within the petcock thus allowing fuel though the feed pipe - the one with the groove as per previous pic. No vacuum, no fuel, unless the valve is switched to prime at 3 o clock. Safety thing I imagine. The feed connection was pulled as per the pic. No o-ring in the petcock body, and also pretty certain it did not leak when I ran it a while back despite no o-ring. However, the groove is surely indicative of an o-ring? - for which incidentally I have spent the last hour rooting through all my bits searching for one and failed miserably. Could have started it otherwise....
ides
ides
- warren3200gt
That explains it. I really dislike those taps, I hear about too many issues with them. If it were my bike I would seal off the vacuum pipe at both ends, use prime as on and on as off. I have the habit of turning off the tap everytime I get off the bike.
Short term fix for no o ring is plumbers ptfe sealing tape.
Ps, your tap needs cleaning
PUM 488 June 2023
Hi Warren
Agreed. I am not a fan either. it seems to work though...for now. I too turn the tap off when finished, but clearly not possible here. I don't like the fact the diaphragm could fail if tap is ON or at RES and allow fuel through when the bike is not running. Yes I have PTFE tape, but the local - and very useful garage shop - should have a suitable o-ring. Yes it's rusty, and yes I will clean it up. Cannot have it spoiling things!
Incidentally the clock surround is deffo gloss of some sort - looks enamel to me and original. I actually prefer it to satin against the chrome pods. Leaning towards respraying it...
Pics to follow. Looks far better with the Euro bars, and everything polished up.
- warren3200gt
Original unrestored clocks from my b1 which I bought new in 77 definately satin.
PUM 488 June 2023
My clock surround as per pic - surely not satin! I also had assurrance from the PO that nothing had been touched from the factory. Herewith also a pic of an ad for my clocks. Looks to have more sheen to it than satin perhaps?
https://www.ebay.co.uk/i/362953607859?c ... gLrBfD_BwE
Moot point though...
gloss black
- warren3200gt
650's, Z900 A4/5, Z1000 satin black. Z1, Z1A, Z1B gloss black maybe?
PUM 488 June 2023
warren3200gt wrote:650's, Z900 A4/5, Z1000 satin black. Z1, Z1A, Z1B gloss black maybe?
they are all the same through z650 z1 z900a4 z1000
- warren3200gt
My B1 650 I bought new in 77. I have owned it since then. I know what has and hasn't been done to it and the clocks haven't been touched. They are definitely satin not gloss.
PUM 488 June 2023
From what I can remember from my Z650 B1 model, the speedo and tachometer bodies were satin black. This also applies to the pods underneath each gauge.
- wheelysteve
My 1977 B1 has untouched clock surrounds and they are definitely gloss black ??
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Users browsing this forum: No registered users and 133 guests
