Fuel tap on my Z1000A2 needs replacing or rebuilding
What are my options please
Fuel tap
Re: Fuel tap
You can get o rings ok (which will stop external leaks) but I couldn't find the rubber sleeve thing with holes in for sale.
If yr rebuilding the tap because it won't turn off the rubber sleeve is likely to be the issue. Mine swelled up and started working again after I left it with fuel in the tank for a few days and a bit of pipe connecting both outlet ports to stop it piddling everywhere. Could try that.
Olly
Olly
Lemmy
Lemmy
Re: Fuel tap
Cheers olly but mine has a minute tear in the diaphragm
And the disc is mangled how that i dont know ?
Users browsing this forum: steve-g and 158 guests
