The Z1000-A1 that I bought in bits came with lots of new spares, including some Hi Level clocks - but they don't fit the original bracket. The bulge on the back of each one fouls the bracket; the fittings etc otherwise line up as they should. Looks like I might be able to file away sections of the bracket but I wondered if anyone knows whether there's a pattern bracket that fits with these clocks?
Also I need to stick new foam on the back of the clocks - how thick should it be? The original stuff is shot to pieces.
Theo
Z1000-A1 pattern clocks fittng
2006 Bonneville T100 (lightly customised) and Z1000-A1 (nearly finished!!!)
Re: Z1000-A1 pattern clocks fittng
Any photos of the offending articles mate?
There's an updated bracket for these. Ring zpower
Taffus wrote:There's an updated bracket for these. Ring zpower
Thanks - I will. I was gonna call Phil this morning but was too busy...
think i may have got mine from cybike, was awhile ago
Thanks all, yes spoke to Phil and they do one and I can see from the photo that it has a bigger space in the centre of each clock bracket. Also appears to come with the foam vibration damping stuff.
https://www.z-power.co.uk/clock-mounting-bracket
Ordered!
Ordered!
Dragging this out of the archives... What are peoples thoughts on these clock sets ??
Andy M wrote:Dragging this out of the archives... What are peoples thoughts on these clock sets ??
They work well at least the ones I have do no wavy needles any more. There was some mods needed to the bulb wiring as I recall and you couldn’t use the original bulb holders and wiring because they were different size.
I have bought a couple of sets this year and they were fine. Everything fitted nicely.
paid up member
chrisNI wrote:There was some mods needed to the bulb wiring as I recall and you couldn’t use the original bulb holders and wiring because they were different size.
Correct!
Users browsing this forum: No registered users and 187 guests
