camshaft repair / replacement question Z1000A1
Z1000 a1 : this is all new to me so not sure if cams can be repaired?
There is some scoring on journals and looks like some kind of wear on exhaust lobe, looks like when chrome wears off parts showing zinc underneath.
Any suggestions regarding experts in the northwest area?
Hope this makes sense, any advice really appreciated.
- warren3200gt
Re: camshaft repair / replacement question Z1000A1
Post as pic of the scoring. "wear" marks are likely heat marks and not a problem but again a pic would help.
PUM 488 June 2023
- Z1streetfighter71
Im actually interested to hear if there is an answer to this, i have a set of POPPY bonville cams that have water damage to one of them through storage, id be very happy to hear there was a reliable place nearer than the states.
Z1streetfighter71 wrote:Im actually interested to hear if there is an answer to this, i have a set of POPPY bonville cams that have water damage to one of them through storage, id be very happy to hear there was a reliable place nearer than the states.
Plenty of places in UK such as Phil Joy Engineering in Hertfordshire that specialise in cam repair and regrinding etc.
Pretty sure SEP , Kent Cams or Newman Cams etc could do the job too .
pictures of camshafts, the marking on the lobe is the exhaust cam , this is the cylinder that was oiling up and on examination has damaged vale stem oil seal. hope these pictures help, thanks again.
john
john
The journals are fine if within tolerances, the cam lobe looks like the hard facing is mullered.
Possibly heat related and infrequent oil changes.
What's the shims like on the affected lobes.
Some aftermarket shims are poor quality and can cause lobe damage.
- Z1streetfighter71
Thanks again Zed, iv saved 2 places to send the cams, this is what the worst of it looks like.
Looks like they have spent a lot of time with water on them, but if they are stock it would probably be cheaper to pick up second hand ones.
- Z1streetfighter71
Oh they are Yoshimura Bonneville Poppy cams, fairly rare on the ground these days, the intake are in good condition but the exhaust are as you see.
If it might be of any help, I recall reading recently that Pop's Y Bonneville profile is very close to the later Kawasaki GPz 1100a /unitrack cam profile. I understand you can get conversion sprockets to adapt the late 2 bolt cam to the early 3 bolt pattern and being as its the exhaust cam, you'd lose the mechanical tacho drive so this would mean using an electric tacho.... but it might be a less expensive option ?
zed1015 wrote:The journals are fine if within tolerances, the cam lobe looks like the hard facing is mullered.
exhaust shim , if the lobe hard facing is "mullered" is it something that is recoverable ?
Cams cam be re-faced but the cost may be more than picking up another good used set .
You would need to contact one of the cam shops i mentioned to find out.
All the z900-1000 kickstart motor cams are the same spec with only fractional differences in lift ( nominally 8.7mm) due to manufacturing tolerances so they aren't hard to find.
That shim has been scuffed by the cam lobe and without having it in my hand it's hard to tell if it's ok to re-use.
Thank you so much for the advice will look out for set of cams, and probably also enquire about repair.
again really appreciated everyone's responses.
john
Stick an ad in the wanted section.
I'd be surprised if you can't pick up a decent set from one of the members.
Users browsing this forum: No registered users and 96 guests
