Hi Guys.
I've got a problem with my Z1b's tacho. At idle it's pretty stable, but the more revs i put on, the wilder the 'swing'. Iv'e been told that the tacho mechanism is oil filled and this oil damps the needle's fluctuations? The oil apparently escapes over time causing the needle to oscillate. It's pretty annoying, especially next to the rock steady speedo needle. If this is the reason, can the mech be overhauled? If so, does anyone have a contact that they can pass on? Or am i potentially looking at another issue?
Tacho needle wobble
Re: Tacho needle wobble
Hi, Al Marshell is you're man for clock repairs, I've used him a few times and he's spot on.
http://z-clocks.co.uk/
Regards, Paul
Regards, Paul
I take it you have already fitted a new tacho cable as this is the first place to look.
Kawasaki GPz750T, Kawasaki ZRX1100R, Kawasaki GPZ1000RX, H**** VF1000RG Rothmans, H**** VF500F2F, H**** CB1100RD, Suzuki GSX1100EFE, H**** XL125K2
Invariably this will be caused the damping fluid within the unit drying out.
Regards
Steve
Regards
Steve
- Nobbyrobby
- new poster
Thanks very much all for the tips and info. I'm on it!
Users browsing this forum: marmck and 86 guests
