Hi all , just purchaced some carbs listed as Z1000 26mm but when i measured the internal bore on the cylinder head end they are 26.8mm . Am i right in thinking they are 27mm .
Kind regards Keith
Carbs
- warren3200gt
Re: Carbs
They 26's. They need to be measured at the slide to get the correct dimension as they taper from the slide to the throat.
PUM 488 June 2023
- warren3200gt
Re: Carbs
Fuel screw, air screw or both?
PUM 488 June 2023
Re: Carbs
Only fuel screw underneath . I now believe they are off a KZ1000a2
https://www.ebay.com/itm/125556603675
- warren3200gt
Re: Carbs
Sounds correct
PUM 488 June 2023
Re: Carbs
If a2 they will have a vacuum stubb on number 3 carb.
