I have asked elsewhere but trying again.
Can anyone recommend a good crank services guy in the Yorkshire area, or perhaps further a field? They seem thin on the ground for bike engines.
Checking for true, balance and weld.
With thanks
Crank Services Recommendations
KZ1000 B4 under light restoration.
Re: Crank Services Recommendations
I think Dave Branch 07802874360 is still doing cranks of this type and of course Ray Debben still does them.
Which crank is it? 17mm small end as per z900 z1000 etc or 18mm small end, as in Unitrak ZX11?
17mm small end (Z1000 Mk2 engine) 1015cc
Gotcha, i have a Debben built crank; stripped, assembled, trued, polished, welded and balanced for sale but it is an 18mm smal end ZX11 version un-fortunately.
Thanks for your help anyway Al
Ray or Steve at Debben Performance, Ringwood. will sort you out.
