Bike lift
- Regular Poster
Bike lift
Is there anything out there that I can use to lift my Z1b to make working on it easier?
I know that a hydraulic ramp is the ideal but I don't have space for one.
Is there something else that will lift my bike to a reasonable height for maintenance - I'm thinking something on the lines of the Abba Skylift that would work with a Z1b
Re: Bike lift
I used a Hydraulic short stand which I can use in the shed if I move the bikes around a bit. Or.... more recently, rebuilding the Z1000 in the dining room
Something like this -
These guys are a good place to start
https://www.motea.uk/motorbike-stand?msclkid=28e1bcd2cb4219f793b4d90c3dcccf96&utm_source=bing&utm_medium=cpc&utm_campaign=UK%204%20-su-%20ConStands&utm_term=constands&utm_content=ConStands%20Brand%20Only
Present
Red '78 KZ - rebuilt from engine up
Other wheels - Couple of old Guzzi's
Past 1994 - 2010
Luminous Green '78 KZ import [BLE 656S]
Past 1994 - 2010
Re: Bike lift
I have a 1jac stand for sale which lifts both the front and rear wheel off the ground. It has adapters for Z1000j, I am sure it could be made to fit an earlier model.
Rob
Rob
Z1000R/ZRX, RD 125LC, Zx7r , Endurance racer, gpz1100b1
- Regular Poster
Re: Bike lift
Graham-A2 wrote:I used a Hydraulic short stand which I can use in the shed if I move the bikes around a bit. Or.... more recently, rebuilding the Z1000 in the dining room
That looks like it might work I don't suppose you have a picture of the stand without the bike do you or the make/model of the stand?
- Regular Poster
Re: Bike lift
Robw wrote:I have a 1jac stand for sale which lifts both the front and rear wheel off the ground. It has adapters for Z1000j, I am sure it could be made to fit an earlier model.
Rob
Rob,
Do you have a picture of the stand or a link to it on the web ?
Haydn
Re: Bike lift
"That looks like it might work I don't suppose you have a picture of the stand without the bike do you or the make/model of the stand?"
I think it was a Constand - have a look on the Motea site site here:
https://www.motea.uk/motorbike-scissor-lift-constands-midlift-xl-hydraulic-jack-500kg-in-black-114968-0
Present
Past 1994 - 2010
Past 1994 - 2010
- Regular Poster
Re: Bike lift
Graham-A2 wrote:"That looks like it might work I don't suppose you have a picture of the stand without the bike do you or the make/model of the stand?"
Thanks for your help
- Regular Poster
Re: Bike lift
Sorry,
Another dumb question - did this set up work with the exhaust on the bike?
Haydn
Re: Bike lift
In the picture I posted the bike couldn’t have an exhaust on because the frame rails were supported directly on the lift deck. It comes with supports for the frame rails which are like long bolts with angle irons on the top. These are intended to give clearance for bits like the exhausts, sidestand, footrests etc.
Present
Past 1994 - 2010
Past 1994 - 2010
Re: Bike lift
there's a member selling something on here at present that might suit - might have to modify the fitting kit to suit
gray
- Regular Poster
Re: Bike lift
gray wrote:there's a member selling something on here at present that might suit - might have to modify the fitting kit to suit
Is that the 1JAC stand earlier bin this thread?
Re: Bike lift
yes , was put up for sale in October and the seller put a post on quoting a price a day or so ago so its still for sale I guess
gray
Re: Bike lift
I have put a link to it above.
Users browsing this forum: Bill P and 150 guests
