Carbs
Jon , You said 903cc engine ! Is it a Z1 or Z900 ? If a Z900 would suggest leaving the 26mm but if a Z1 the newer 28mm will be OK if you change the pilot jets / mains jets to suit . I ran my Z1B for years with a set from a Z1000 MK2 and no problems . I had to blank off vacuum fuel tap feed and they fitted straight on with standard air filter also !
Zeds-R-Us
If you want to knit pick they will give slightly better top end and slightly worse midrange response - air velocity when opening up will be lower on the 28s. I would doubt you will notice for normal riding, stick them on and do a comparison with the 26s and see which you prefer.
Users browsing this forum: Bing [Bot] and 30 guests
