Checking Valve shims
#1 PostAuthor: chrisu » Sat Dec 20, 2008 1:53 pm
for those who haven't ever tried doing your own valve shims here is an idiots guide (me) to it. hopefully it'll make sense. This is shown on my Z1000H but the principle is the same for all 1980 or earlier Z1, Z900s & Z1000s.
Always do one at a time and be patient.
So to start remove cam cover & spark plugs plus the timing/points cover.
Adjust the cams using a 17mm spanner on the advance/retard nut until the cam lobe is pointing away from the shim/follower.
Now check the gap using a feeler gauge - i tend to use 0.05, 0.1 and 0.15mm to see how big the gap is. If 0.1 fits and 0.15 doesn't then i am happy. We'll get to what happens if there is no clearance later.
If the gap is incorrect you will now need to remove the shim. You'll need the following tools - a magnet on a stick, a pick and the kawasaki shim tool.
Rotate the cam until the lobe has opened the valve fully. Now insert the tool as per the photo. this holds the bucket open while you then rotate the cam away. This enables you to remove the shim using the pick/magnet.
Note before you do this set the bucket so the little notch is visible - this will make it easier to remove the shim with the pick.
now you've got the shim out you need to measure it. it may be stamped but some are not. If not use a micrometer to check thickness.
Now if you know the gap you have and the shim thickness you can work out what size shim you need. I tend to check all, write them down and work out what i can shuffle around and what needs replacing.
once the replacement shim is obtained then replace it, make sure its seated properly and rotate until the cam lobe is opening the valve. you can now remove the tool and do a full rotation to ensure its all seated properly.
go onto the next one....... easy.
What to do if there is no gap ? Well if there is no measurable gap but you can still rotate the shim bucket then assume it is 0. If you can't rotate the shim bucket then its negative and you'll need to measure again with a smaller shim...... :(
hopefully you'll have measured all and will have a shim smaller from another valve. If the one with negative gap is also the smallest you're really unlucky.......
some useful additional information/pointers from Rich.........
For aftermarket cams Web, Andrews, Kent etc check what clearance you should have with maker, mine run .10 to .20 mm also Mk2s run a slightly bigger clearance than 900s etc.
Write the shim sizes in the back of your workshop manual, then when the next time comes you don't have to take the shim out to measure but can work out if you have the correct ones already.
An offset ring / socket and tommy bar is better as it clears the pickups better.
and you can't emphasise this enough:
Take care when rotating the cam with the bucket holder tool in place, heads have been ruined by rotating the wrong way.
tlc
#2 PostAuthor: tlc » Sat Dec 20, 2008 2:03 pm
Does this guide work for the round cam cover model Chris ? :lol: :lol:
000zeds
#3 PostAuthor: 000zeds » Sat Dec 20, 2008 2:31 pm
Exactly same !
Zeds-R-Us
Kev1R
#4 PostAuthor: Kev1R » Sun Dec 21, 2008 2:12 pm
This guide is excellent
This is exactly the type of thing we should have in the 'downloads'
section - (maybe as a word document)
Guides like this could build into a useful resource - alot of which is maybe already on the site in one form or another - but not easy to locate quickly.
anyhow - well done
cheers
Kevin
Steve R
#5 PostAuthor: Steve R » Sun Dec 21, 2008 10:31 pm
Nice one Chris. The only thing I would add is to allways measure them with a micrometer even if they have the numbers on them still; as I have had them different to the number when I measured them, dont know why?
Only found out after putting the new ones in and rechecking and finding the gap still wrong, thought I had done the sums wrong :roll: then measured the old shim and found it was different :evil:
Dodgy Z1B
#6 PostAuthor: Dodgy Z1B » Sun Dec 21, 2008 11:58 pm
This may be a stupid question but here goes, is it possible for the piston to hit the valve if it is being held open by the valve tool? I have only adjusted shims a couple of times before on an old gs I measured the clearance and then removed the cams as I didnt have the gs tool which i did try to copy by making one out of mild steel at the time but it didnt work very well.
bigmac103
Shims
#7 PostAuthor: bigmac103 » Tue Dec 23, 2008 9:41 pm
Chrisu,
This is excellent, well done. Can you do the same for setting up the timing??? The diagram you did in a previous thread is good but this kind of photographic detail is priceless.
Dodgy Z1B brings up a good point about the piston touching the valve with the shim tool in place, surely it would be better to take the tool out to check the clearance.
Lost in the desert somewhere
Steve Cooke
Re: Shims
#8 PostAuthor: Steve Cooke » Wed Dec 24, 2008 2:06 am
bigmac103 wrote:Chrisu,
The tool doesn't hold the valve down so far as to make contact and you only rotate the camshaft enough to install the tool then a little further so you can remove the shim. You have to check the clearance prior to installing the tool, the tool is purely for the removal/replacement of the shim.
bunnysZ
Granny Magnet
#9 PostAuthor: bunnysZ » Wed Dec 24, 2008 12:12 pm
nice to know you have the tools and the know-how chris, as I will be booking you in after xmas for mine :D
HARRY4448
Checking shims.
#10 PostAuthor: HARRY4448 » Wed Dec 24, 2008 1:25 pm
Outstanding.
This is how it should be shown in all those so called expert mechanics books like Haynes do.
You should put a restoration book together Chris
(with lots of photos obviously)
Maybe a video of the procedure?
Merry Christmas to you.
sanderz
#11 PostAuthor: sanderz » Mon Sep 12, 2011 8:03 pm
Have just followed this excellant guide to 'size up' the shims :up
Only thing is - seems 7 out of 8 of the shims i've got, look like they've been ground to obtain the clearance. Is this a common practice? Or am i better to play safe and put new ones in?
The 'ground' side was inserted against the bucket not the cam but am i right in thinking the hardness has been lost there?
Any advice appreciated.
Wots up DOHC
#12 PostAuthor: Pigford » Mon Sep 12, 2011 9:27 pm
If they've been ground I'd be a bit warey, even if face down
Minimum thickness should be over 2.00 mm :?? :!:
sanderz
#13 PostAuthor: sanderz » Mon Sep 12, 2011 9:47 pm
Cheers there Pigford, think i'll change em for peace of mind then.
Smallest shim sizes are 2.35 and a 2.40
All the others are between 2.50 - 2.65
Thankfully no nightmare issues with sizes, which was what i'd initially thought when i saw they'd been ground down.
Wots up DOHC
tedsonthezed
#14 PostAuthor: tedsonthezed » Tue Sep 13, 2011 11:03 am
Well done chrisu - this has been overdue for a long time. Couldn't have been explained better than that. Using a magnet is an obvious thing to use - much better than a pair of tweezers.
This document may, or may not be of help in this. It's one of a pile of service bulletins that Jerry sent me for the archive and is pretty self-explanatory.
You want how much?
PAULJAC47
#15 PostAuthor: PAULJAC47 » Tue Sep 13, 2011 3:55 pm
Steve R wrote:Nice one Chris. The only thing I would add is to allways measure them with a micrometer even if they have the numbers on them still; as I have had them different to the number when I measured them, dont know why?
Found this seem to remember its something to do with the tolerance written on the shim some are A, seem to recollect,always use a good old fashioned mike to check..Paul J
