Checking Valve shims
Farmer
#46 PostAuthor: Farmer » Sun Feb 08, 2015 12:25 am
Bugger :shock:
1981 KZ1000 K1 LTD
Farm Boy with an O Level in Metalwork and not much else.
Everything in Sussex is a She, Except Tom Cat and She`s a He.
Farmer
#47 PostAuthor: Farmer » Mon Feb 09, 2015 2:10 pm
I take it then you can only take 1 shim out at a time and then replace it and then move onto the next, or can I take all the shims out before I replace any ? :)
1981 KZ1000 K1 LTD
#48 PostAuthor: zed1015 » Mon Feb 09, 2015 6:02 pm
Farmer wrote:I take it then you can only take 1 shim out at a time and then replace it and then move onto the next, or can I take all the shims out before I replace any ? :)
One at a time only.
If you allow the cam to run direct on the bucket you risk damaging the cam and buckets as the cam will jam against the raised lip on the bucket.
Steve Cooke
#49 PostAuthor: Steve Cooke » Mon Feb 09, 2015 6:38 pm
One at a time, measure each gap and each shim and when you've got all eight on paper, work out which ones you can swop around to reduce the amount you will need to get.
Farmer
#50 PostAuthor: Farmer » Tue Feb 10, 2015 9:34 pm
Cheers Guyz, I am awaiting the magic tool. :)
1981 KZ1000 K1 LTD
thorgrimm
#51 PostAuthor: thorgrimm » Sun Apr 19, 2015 10:38 am
Guys
what would the valve clearances be for a gpz1100b1 1981 engine
with 1983 gpz11 unitrak cams.
The buckets are over not under so dont need to take out the cams.
gray
#52 PostAuthor: gray » Wed Apr 27, 2016 6:52 pm
re the "got no clearance at all" problem- I bought 1 of the very smallest shims , so if I ever get no clearance , stick the smallest shim in , check its clearance (cos it'll always give clearance) then use the table to find the right shim
gray
Nosher903
Re: Checking Valve shims
#53 PostAuthor: Nosher903 » Wed Jul 12, 2017 1:42 pm
This guide has come in so handy. It helped me realise I was getting the valve tool located slightly wrong as I was getting hardly any wind back on the crank before I felt the motor "lock". By comparing the pictures, I knew I had the right tool but was executing it wrongly - something Haynes and the factory manuals couldn't have helped with. All sorted now, thanks to Chris U and the Club's shim swap shop. :)
Z1b, GPZ900r, XJR1300
#54 PostAuthor: chrisu » Fri Jul 14, 2017 12:24 pm
glad it helped !
:beer
ianali
#55 PostAuthor: ianali » Thu Nov 16, 2017 4:02 pm
Have read through this very useful section and I have a question. When I fit the valve holder tool do I then rotate the cam lobe away from the direction of the tool and then the reverse after I've changed the shim? Hope that makes sense to someone!
Ian.
#56 PostAuthor: chrisu » Thu Nov 16, 2017 4:28 pm
yup -away from the tool
ianali
#57 PostAuthor: ianali » Thu Nov 16, 2017 4:45 pm
Thanks Chris. I have re shimmed many kawasakis but not for many years. It's amazing how much I've forgotten.
#58 PostAuthor: chrisu » Sun Nov 19, 2017 4:14 pm
this is an example of how i map the shims required. also keeps a log of whats in each bike as well
Z1R shims - june 2016.xlsx
(12.41 KiB) Downloaded 106 times
