Checking Valve shims
1975-S1C
Re: Checking Valve shims
#61 PostAuthor: 1975-S1C » Fri May 31, 2019 6:05 pm
Ok, thanks for the advice. I’ll get the shims I need to drop the two .19’s down to .14.
Probably leave the .17 as is.
Cheers again
Safo
#62 PostAuthor: Safo » Tue Jul 09, 2019 5:42 pm
First of all what a great articale , as I am a reborn z fan and owner I have been re aqainting myself with my kz900 w/s manual, and just to reiterate it also states that you should never grind the shims as they can fracture, but you can grind the valve stem a little to bring it back to spec (on a purpose made tool of course, and with the valve removed
