wheels,speedo,rev`counter and ratio ?
Keefleaf
#1 PostAuthor: Keefleaf » Tue Feb 24, 2009 10:26 pm
Is it possible to convert a Z650 speedo to 160mph from 140 mph?
If the front wheel is the same size then it must be possile to get a speedo
face sticker, [BIG FLUFF],and convert?..Is it?
The Rev counter only goes upto 10,000rpm,but who`s looking?At those revs,you should be looking where your going :)
PaulMceleney
Chunks
#2 PostAuthor: PaulMceleney » Tue Feb 24, 2009 10:41 pm
big fluff done me a clock face for a z650 only a couple of weeks ago thats goes upto 160, he does a fantastic job iam not very good at posting pictures on here, but if you want i could take a picture of it and email the picture to you if you give me your email address hope this helps paul
Big Fluff
#3 PostAuthor: Big Fluff » Wed Feb 25, 2009 8:33 pm
You need a set like this making up to enable the speedo to work correctly.
PM me and we'll go from there if you want a set making - Whatever colour/style you like.!
Regs, Will.
#4 PostAuthor: Ginger Bear » Wed Feb 25, 2009 10:14 pm
Big Fluff, that's very interesting stuff you do there. I am running a 17'' front wheel, with a ZX7R speedo drive. I know the speedo is very innacurate because of this. Can you produce a clock face to compensate for this? I know the 'recorded' mileage still wouldn't be accurate, but that's no big deal.
Big Fluff
#5 PostAuthor: Big Fluff » Thu Feb 26, 2009 1:34 pm
Yep, can do anything you want.
You give me an idea of what should be where and I'll make a set up for you.
PM or email me with your findings etc.
Will.
#6 PostAuthor: Ginger Bear » Thu Feb 26, 2009 2:22 pm
Will,
That sounds great. I would like to source another set of clocks first (not gonne be cheap, I know) Then I will run with a GPS speedo or similar to see where the numbers need to go. Will PM you when I've done me research.
Keefleaf
#7 PostAuthor: Keefleaf » Thu Feb 26, 2009 8:56 pm
hallo Will,P.M. on the way :)
