gpz1100 engine/z1000 frame
Hi , i have a z1000a2 frame and will be puting a gpz1100 engine into her any mods i need to do before i start,
- big green bus
- big green bus
i put one in a 76 frame , i had to cut off the underside mounts of the frame (ones with pear shaped nuts) and make new front lower mounts, top rear and top front i remade in alloy although i could have used a mix match of the ones i had. also the rear spacers from the 11 needed turning down, the top rear bolt on the eleven is a larger dia. but a fairly easy swap. the 11 motors are shorter due to not having kick start casing. the kick start Z's wont go in a unitrac frame (dont ask how i know this).
- london calling
GPZ1100 / Z1000A2
THANKS FOR YOUR REPLY'S WILL HAVE A GOOD THINK ABOUT THE BEST THING TO DO OVER A FEW PINTS
