Supercapacitor battery experiment.
j.wilson
#16 PostAuthor: j.wilson » Wed Jun 05, 2013 6:47 pm
Sadly I don't think the RR is the problem.
I just consume too much power for the generator. Its only 20 amps at 5000rpm.... how fast is that in top gear?
I'm hoping that there is a heavy duty alternative out there and then I can reduce the load a little and it will be ok.
z650/1400 bonneville hybrid.
#17 PostAuthor: Rich » Thu Jun 06, 2013 7:35 pm
have a word with your local motor rewind specialist about rewinding it to put out more power
j.wilson
#18 PostAuthor: j.wilson » Thu Jun 06, 2013 8:17 pm
Westcountry windings- but they are a bit vague whether it will be better than standard even tho they are twice the price.
They say they have no data for what they can do, I just need then to tell me what more they can do than standard.
Waiting for a response from them.
j.wilson
#19 PostAuthor: j.wilson » Thu Jun 06, 2013 8:26 pm
These people claim theirs is 15% more power.
http://www.electrosport.com/street-bike ... z1100.html
#20 PostAuthor: ZedHead » Fri Jun 07, 2013 9:53 am
j.wilson wrote:These people claim theirs is 15% more power.
Jeff Saunders does the same for $79.99
http://www.z1enterprises.com/ItemDetail ... EM48-98630
j.wilson
#21 PostAuthor: j.wilson » Fri Jun 07, 2013 9:59 am
Yes, but no stock and back order not allowed!
I'm a bit stuck at the moment as the Electrex don't supply their uprated stator- that had problems with them being too powerful, and Westcountry windings don't think they will get much more out of it.
Hmm.
Could I get electrex to tell westcountry windings to tell them how to wind their discontinued uprated version???
Or buy one off the shelf from the US?
j.wilson
#22 PostAuthor: j.wilson » Sat Jun 15, 2013 4:20 pm
Ordered a replacement fuel pump. Going to have to squeeze it in somehow because its 20mm longer but at least has the same outlet fittings.
It consumes 5.2 amps not 10amps. So this should solve my power problems.
http://www.fuelpumpsonline.co.uk//bosch ... -187-p.asp
ade woollams
#23 PostAuthor: ade woollams » Sat Jun 15, 2013 5:02 pm
j.wilson
#24 PostAuthor: j.wilson » Sun Jun 16, 2013 12:05 am
thanks that's interesting
j.wilson
#25 PostAuthor: j.wilson » Fri Jun 21, 2013 8:35 pm
Well I put a lower power fuel pump on- that's 5amps instead of 10amps. The bike will rebuild its charge now quickly whenever it is ridden- on tick over it decays slowly, however with the light on it will maintain the charge at over 2000rpm but under that it will decay. Also, when it has decayed it wont rebuild the charge with the light on.
Hmmm, it looks like the LED headlight is necessary!
There is something about the resistive load of the headlight that is just too much for it. The city light is (and tail light obviously) is ok, but the extra load of the headlight is not.
firyembers
Custard Creem
#26 PostAuthor: firyembers » Wed Feb 05, 2014 2:07 am
Hi John
Could you go the route of a drive belt pulley and a small alternator.
Some i have seen are about 4" dia or so and can do 50-90 amps or so..
Maybe even sourced from the new Kwaks as they now mount a pulley driven alternator behind the engine..not sure there output amps though without looking.
http://www.racemettleltd.co.uk/alt.html
http://www.sbdev.co.uk/Electrical/Alter ... nators.htm
There maybe though a rpm limit to an alternator though.
Life shouldn't be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, cigar in one hand, beer in the other, body used up, totally worn-out and screaming, "WOO HOO, what a ride!"
j.wilson
#27 PostAuthor: j.wilson » Wed Feb 05, 2014 9:32 am
That could work, I'm still going to try an LED headlight first. I'm waiting for Harley to release their rhd sportster LED headlight- it will fit right in.
Users browsing this forum: zed9 and 101 guests
