A quick wipe with an oily rag should sort it!
The bike is a Z1000H, but the motor is Z1A, but if I cant find a replacement one from a MKII or ST, I will use the A2 engine that was destined for the Harris and rebuild the Z1 lump later.
Big Fluff wrote:Good luck with the build Harry, love the shape of the MkII so will be following the build.
Are you going down the std route or subtle mods
