Stan's z1000st project
Re: Stan's z1000st project
Well done with the conversion to chain, a right B******* job to do.
Are you going to change your side panel badges to MK11 ones, otherwise you may confuse a few people.
- Fred the Zed
Desperate Stan
- Regular Poster
ADRIAN H wrote:Well done with the conversion to chain, a right B******* job to do.
Cheers for all the positive feedback!,hadn't planned to change the badges tbh..more fun to leave em on I reckon! ,do need to sort the exhaust tho ..the harris is on its last legs,collector box is shot and had to have the pipe welded as it almost snapped over xmas.Not sure what to get tho really?
Desperate Stan wrote:ADRIAN H wrote: do need to sort the exhaust tho ..the harris is on its last legs,collector box is shot and had to have the pipe welded as it almost snapped over xmas.Not sure what to get tho really?
I have a spare Marving 4 - 1 you can have £100 ? May need to see how the rear mount fits though, before buying ?
Rear mounting bracket needs rechroming, and where downpipes meet needs a repaint.
picture with exhaust fitted.
Desperate Stan
- Regular Poster
Cheers ,am very interested! pm sent thanks
Desperate Stan wrote:Cheers ,am very interested! pm sent thanks
have nt received one
Desperate Stan
- Regular Poster
Merry xmas all ,since my last post have only covered 200 odd miles.Thanks to Adrian H who kindly offered me a nice condition Marving pipe ,managed to make it fit and looks much tidier than my old harris! Need to sort a proper hanging bracket at present it fouls the rear footrest so have had to remove it for now.took this pic today after a run down to Bournemouth to visit a mate ,have also fitted a Pingel fuel tap now ,my standard one fouled the bigger cv carbs also it seems the bike is running lean at higher revs ,Debbens advised trying the tap which would flow more fuel..roads weren't great today so was being quite careful out but did seem to be pulling better ,if it dosn't cure the problem will try bigger jets at present they are 132.5? would be interested to know what other people are using in similar carbs?thanks..looking forward to getting out a lot more next year now all the hard work is done! cheers Stan.
Lovely job, hope to see in the flesh one day.
Desperate Stan
- Regular Poster
ADRIAN H wrote:Lovely job, hope to see in the flesh one day.
Cheers Adrian ,will do! i'll be making a lot more effort to get out on the bike in 2018
Desperate Stan wrote:ADRIAN H wrote:Lovely job, hope to see in the flesh one day.
Sounds like a plan.
Nice looking bike Sir.
What is the benefit of running the cv carbs please ? And which model are they from ?
Thank You
Thank You
