KZ900 the beginning
Nick.s
Re: KZ900 the beginning
#16 PostAuthor: Nick.s » Fri Jun 22, 2018 3:20 pm
Thanks, I thought the stand bracket would be expensive.
#17 PostAuthor: deka » Fri Jun 22, 2018 3:31 pm
Nick.s wrote:Thanks, I thought the stand bracket would be expensive.
put a wanted add someone may have one from a damaged frame, i
GPZ1100 A1 zrx1100 gsa1200
#18 PostAuthor: deka » Sat Jun 23, 2018 9:13 am
Nick.s wrote:I’ll keep an eye out for those dimensions, where did you find the hinges and the side stand bracket? Mine just has the foot plates with the stand built into that
Let me know where you would like the measurements taken from
Nick.s
#19 PostAuthor: Nick.s » Sun Jun 24, 2018 8:23 am
I think I’ll get a seat first and maybe a tank, my tank has the wrong filler cap it’s a twist fit probably from its police days. I presume the correct tank has a flip cap? Unless anyone knows better?
I’ll contact you later, thanks for you help so far.
Nick.s
#20 PostAuthor: Nick.s » Tue Jul 24, 2018 5:05 pm
Hi again, hope the build is going ok. I am now going down the standard bike route, I noticed you welded on lugs for the passenger foot pegs, could you tell me the position of these? I don’t want to put them in the wrong place.
Nick.
#21 PostAuthor: deka » Wed Jul 25, 2018 7:35 pm
It’s not so critical but from the top of the exhaust hanger to the bottom is 270mm I can take pics if you want
Nick.s
#22 PostAuthor: Nick.s » Wed Jul 25, 2018 9:39 pm
Thanks mate, that’s all I needed. I didn’t want to put them too low so they hit the exhaust pipe when folded down.
Thanks again
Nick
Nick.s
#23 PostAuthor: Nick.s » Sun Jul 29, 2018 7:56 am
Sorry to keep on to you mate but I need more advice, I’m about to put the side stand bracket on but I’m not sure how critical the angle is, any ideas?
Nick :biggrin
#24 PostAuthor: deka » Sun Jul 29, 2018 8:32 am
Ill be honest with you I had to take @ gamble on the angle of the side stand after studying others bike pictures. Just hoping I got it right as the bike if far from finished so it will be a longtime until I can be sure. Hopefully some one may be able to advise
Nick.s
#25 PostAuthor: Nick.s » Sun Jul 29, 2018 10:58 am
Nick
Nick.s
#26 PostAuthor: Nick.s » Sun Jul 29, 2018 11:18 am
I know what you mean, I think I will do the same
Thanks anyway
Nick
#27 PostAuthor: deka » Mon Dec 03, 2018 9:34 am
Bought a used generator cover due to mine being in a terrible state this is the replacement before work started
After a bit of work this is the stage now Plus others of course
#28 PostAuthor: Philippe » Mon Dec 03, 2018 4:54 pm
Hi Derek
you did a beautyful job! It's like a new one! :brav2 Continue that way and keep us informed with pictures!
Go for it!
#29 PostAuthor: deka » Mon Dec 03, 2018 5:22 pm
thanks philippe. Need to do the fork legs next
#30 PostAuthor: deka » Sun Mar 03, 2019 7:07 pm
Been a while since I have been on as still collecting missing parts, I have some of the major pieces at the chromes and have been filling in my time cleaning up the cases.
Latest jobs have been to fit a tyres to the re laced rear wheel..
The old check twice came into play. I checked to make sure I had the rotation of the tyre pointing the right way and fought to get it on the rim and then noticed it was the wrong way ahhhh :x ok take of a start again this time checking more than twice. Last part of getting the tyre on and nipped the tube....... off to the shops for a repair set and and finally job done and holing air.... no such problems with the front
