New GPZ1100B1 project arrived today
JimBoUK
#1 PostAuthor: JimBoUK » Wed Nov 27, 2019 1:42 pm
Hi all,
So my new project arrived today. A GPZ1100B1 US import:
Now to decide what to do with it ?
My first thoughts were go original but …
It's been converted to carbs. Everything to do with the electronic ignition has been removed and the injector holes filled with metal putty.
Although the exhaust is reasonably good for the age it is a B2 exhaust (it has the Kawasaki badges)
Being a US import I expect going original will give it less value than a UK bike so is maybe less justified ?
I might be influenced by reasonable feedback but my probable plan is to go original paintwork (red) with 4 into 1, braided hoses, maybe a fork brace, maybe deep braced swing arm, maybe different rear shocks and leave the carbs.
If I go for a 4 into 1 I guess the exhaust will have some value. Any idea how much ? (it will help pay for other bits).
Its got a dent at the top of the offside down pipe and a small dent just in front of the indentation on the left side for the side stand. Considering age it's very good with no rot, a few scratches and original baffles
Sgt.Pinback
Re: New GPZ1100B1 project arrived today
#2 PostAuthor: Sgt.Pinback » Wed Nov 27, 2019 2:03 pm
I´d give her correct paint and seat.
Good B1 seat for sale I have.
Carb wouldn´t bother me.
If you want sell the exhaust i´d offer you EURO 550 + shipping cost. Would like to see those dents anyway.
Cheers, Uli
JimBoUK
#3 PostAuthor: JimBoUK » Wed Nov 27, 2019 3:04 pm
Here are pics of the exhaust dents
Sgt.Pinback
#4 PostAuthor: Sgt.Pinback » Wed Nov 27, 2019 3:10 pm
Ah, sadly the one on the downpipe is too big for me. Thanks.
Cheers, Uli
#5 PostAuthor: Philippe » Wed Nov 27, 2019 3:55 pm
Hi JimBoUK
great project you have there! Very sad about the dent in the N°4 downpipe...
The exhaust of a B1 wasn't black chromed, it was painted black and it had no badges. The brackets were bolted on like on the B2. The GPZ1100 Uni-Trac had the brackets welded on the silencers.
It's a shame that the holes for the injectors in the head are filled with metal putty...but are you sure it's putty? Normally that would melt due to the heat of the burning gasses in the compression chamber. But OK, so be it.
I hope you succeed with your project and don't forget to put some pictures of your progress.
Coose
#6 PostAuthor: Coose » Wed Nov 27, 2019 4:09 pm
Don't put it back to standard, it'll be awful, flexible and dull. Relive your youth and do the mods as you suggest like you would've done back in the day - trust me, it makes an average bike into a good one! :wink:
(If you hadn't guessed I'm not a rivet counter - I don't get it as nobody had a standard bike back in the day....)
#7 PostAuthor: Ginger Bear » Mon Dec 02, 2019 7:14 am
I agree with Coose.
Mod it as you would have done back in the day.
# 104
#8 PostAuthor: Bill P » Mon Dec 02, 2019 11:59 am
Make it how you'd have wanted it back in the day :)
don't the yanks luv a gaudy seat
weaver
#9 PostAuthor: weaver » Mon Dec 02, 2019 12:51 pm
Dents in the pipe can be taken out by filling with water and putting in the freezer....if you have a large enough freezer :D
Gyesdad
#10 PostAuthor: Gyesdad » Tue Dec 03, 2019 12:36 pm
Hi Jimbo,
I went to see the bike in the flesh and it's a great starting point. Whatever you choose to do it will be another Zed back on the road. Look forward to seeing how you progress with the project.
Gary.
JimBoUK
#11 PostAuthor: JimBoUK » Thu Dec 19, 2019 1:19 pm
So I managed to get her running briefly before starting the strip down.
Actually sounded quite healthy
After a run, a compression check showed 3 were low with 1 only having 90psi
The strip down begins:
This project is going to take quite a while due to a lack of spare time.
So I wanted an engine stand which I could move if needed.
I found one by Sealey for about £80 but the weight limit was 75KG. I think the GPZ engine is a bit heavier than this so it might not be too stable.
I found another one but it was bench mounted and £160
In the end I got 2 car engine stands for £37 each and joined them together. After making some brackets out of angle iron it's just the job and is strong enough to hold any bike engine going.
Very pleased with the result and the engine can spin round as needed to do work
Next stage strip and rebuild the engine :)
#12 PostAuthor: Philippe » Thu Dec 19, 2019 1:29 pm
Hi JimBoUK
that's very well done!
Good luck with the disassembly!
Julian_Boolean
#13 PostAuthor: Julian_Boolean » Thu Dec 19, 2019 1:33 pm
Coose wrote:Don't put it back to standard, it'll be awful, flexible and dull. Relive your youth and do the mods as you suggest like you would've done back in the day - trust me, it makes an average bike into a good one! :wink:
I may have gone a bit too far with the above, we'll see when I get it back together and running properly
On the subject of engine stands, my engine is currently sat on a Workmate in RobW's garage
redzee
#14 PostAuthor: redzee » Sat Dec 21, 2019 8:44 am
Great project and an excellent idea for your engine stand. One thing I'd forgotten about is how huge the clock binnacle was on those bikes, no need for a cockpit fairing.... :shock: :shock: :shock:
Eight valve grunt.
JimBoUK
#15 PostAuthor: JimBoUK » Thu Jan 02, 2020 7:47 am
Engine now stripped.
I'm looking for a new head instead of trying to fix all the butchered threads.
The rest is looking OK.
I've measured pistons, bores and rings which are all well within service limits.
Still gotta properly check everything else
The bottom of the engine was full of metal filings. These all fell back up into the engine when I turned it upside down.
I can't find any damage to cause this so assume it was a previous problem and the bits have been in the bottom ever since. Probably done when the head was butchered.
Users browsing this forum: Jumbo and 23 guests
