Modified Z1A project....
Steve R
#121 PostAuthor: Steve R » Thu Apr 03, 2008 10:00 pm
Stunning :xbou
RALPHARAMA
#122 PostAuthor: RALPHARAMA » Fri Apr 04, 2008 7:55 am
She looks awesome :!:
Ralph Ferrand
ROZZER
#123 PostAuthor: ROZZER » Fri Apr 04, 2008 7:00 pm
Best I've seen in a very long time- a credit to you sir.
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
Dark Skies
#124 PostAuthor: Dark Skies » Fri Apr 04, 2008 8:53 pm
A thing of beauty.
KZ1000-M1 CSR
davejames
#125 PostAuthor: davejames » Sat Apr 05, 2008 12:26 am
I'm sure I've said before how good that looks Whatever, but I'd go as far as saying it's probably my favourite modified Zed of all time. :D :D
Mucho respect Sir on your bike building skills :D :D
Whatever
#126 PostAuthor: Whatever » Sun Apr 06, 2008 12:49 pm
Wow!!! Thanks for saying all those nice things.
I have to say that all the previous positive comments during the build really spurred me on and gave me a lot of encouragement to press on ..... so cheers for sharing the enthusiasm and I have certainly enjoyed posting the progress reports and pictures.
I only have to rejet for the K & N's now to finish the job because it is well lean opening the throttle through mid range and although I haven't done a wide open throttle plug chop it is surely going be lean there too??
It has 107.5 main's so I was thinking of fitting 120's and raising the needle either 1 or 2 grooves??? can't decide.....experience educated clues anybody?
I decided to ride it the 22 miles from work to home on Saturday afternoon....which was all good until within a mile or two....when it absolutely pissed down!! They are doing a load of roadworks near home as well so the roads were really muddy!
What a bummer. Its only dirt, and I have 'finished' the bike to cope with weather without fear of corrosion etc, but I was a bit glum to get off and see the engine covered in mud!
At least that has got the 'first time out in the wet' nonsense straight out of the way and I don't have to be too poncy or precious about it now.
I have a couple more pics to take and post as I would like to post a pic of my standard A4 next to it. I should be able to take a pic of the two bikes later in the week so that will finish the topic nicely.
#127 PostAuthor: Pigford » Sun Apr 06, 2008 12:58 pm
Whatever, wot carbs are you running now.... did you get the 33's from Jack AVON Calling :?:
Whatever
#128 PostAuthor: Whatever » Sun Apr 06, 2008 5:21 pm
Pigford wrote:Whatever, wot carbs are you running now.... did you get the 33's from Jack AVON Calling :?:
No...they are the standard original set of carbs which ran well before with a straight thru' 4 into 1 pipe but standard airbox....so I just need to correct for the K&N's.
#129 PostAuthor: Pigford » Sun Apr 06, 2008 6:33 pm
You wanna go up 10-15%, best to go high to start with. :wink:
Standard pilots are 17.5, so you may need to go up a size or so 20.0 - 22.5.
I'd leave the needles to last. :shock:
K&N's and std carbs can be a pain, so be warned...... You'll probably end up reverting back to std air box or get some better carbs :??
bunnysZ
Granny Magnet
#130 PostAuthor: bunnysZ » Thu Apr 02, 2009 6:48 pm
whatever happened to whatever and his bike.
if you are still around and monitoring the site are you taking it to the ACE again this year...
whatevers bike and his mates z1000a2 are 2 of the best modified bikes I have ever seen.
tlc
#131 PostAuthor: tlc » Thu Apr 02, 2009 7:46 pm
First time I`ve seen this.
One word ......................... AAAAAAAAWESOME :!:
#132 PostAuthor: Ginger Bear » Fri Apr 03, 2009 8:51 am
tailiftchris wrote:First time I`ve seen this.
Me too..........Amazing!!
RALPHARAMA
#133 PostAuthor: RALPHARAMA » Fri Apr 03, 2009 8:58 am
He took it to last years Ace and I have a feeling he rocked up at the Yorx rally as well. Cracking bike :D
Ralph Ferrand
maralyn
#134 PostAuthor: maralyn » Fri Apr 03, 2009 9:05 am
Stunning,.......Awesome,......Pretty,.........Classey,......Tastefully done. :D :D
Hat's off to you 'Sir'
Some days I wake up Grumpy.
..................Some days, I just let her sleep.
Redbeard
#135 PostAuthor: Redbeard » Sat Apr 04, 2009 9:53 am
Its been said time and time again but that is an incredible bike, best zed i've seen so far. Everyone should see this!
1979 Z1000ST
Users browsing this forum: deka and 56 guests
